Engine missing
Old Mar 8, 2010 | 06:49 PM
Mike in Oregon's Avatar
Mike in Oregon
Thanks guys! I'll start narrowing it down tonight.
Old Mar 8, 2010 | 07:06 PM
Wonderbob's Avatar
Wonderbob
Originally Posted by xxxflhrci
I'll bet he rides in dirt laden high speed air, too...LOL....Been blowing my bikes off with a leaf blower for over 10 years and had zero problems.
Back on topic....I'll bet you have a leaky plug wire that got wet.
Not to pile on but....unfiltered air? A la hair dryer/clothes dryer/fan/window air conditioner or like breathing? If it's good enough for my lungs its good enough for my Harley!
Old Mar 8, 2010 | 07:17 PM
MDodson's Avatar
MDodson
In 4 years I have only bucket washed my bike maybe 8 times ever other time has been at the car wash. I get funny looks at the touchless car washes all the time. lol I just dont blast any electrics
Old Mar 8, 2010 | 07:22 PM
1plumr1's Avatar
1plumr1
Originally Posted by Mike in Oregon
You don't want to know! I think it's called a................pressure washer???
If you washed it with a pressure washer, better check the axel bearing grease. I know folks who have had bearing failure which leads to axel failure which leads to crashes, caused by water penetration from a pressure washer.
Old Mar 8, 2010 | 07:24 PM
BoomerBob's Avatar
BoomerBob
Have you looked everywhere? An engine doesn't just go missing all by itself. Maybe a neighbor or friend borrowed it.
Sorry. Couldn't resist the way this thread was going ...
Check for cracks in your plug wires and be sure to blow out the plug wire ends at the coil. The dielectric grease is a good suggestion too.
Old Mar 8, 2010 | 08:51 PM
Mike in Oregon
Yeah, I learned a lesson the hard way I guess. I'm going to find the initial problem, then get the axles re-greased ASAP! Thanks for the input.
Old Mar 8, 2010 | 09:54 PM
Wonderbob's Avatar
Wonderbob
Mike, WD40 sprayed on the wires and electrical components should get rid of the moisture. Just let it sit long enough to evaporate (an hour or so) because it is combustable!
Use care so you dont get overspray on your paint etc. Unfortunately your bike will need to be washed again (this time using only a limited amount of water pressure).
Old Mar 8, 2010 | 11:02 PM
paguy's Avatar
paguy
Mike everybody is looking at wet electrics. Did you mess with the plug wires when washing or drying? Also, you may have purchased bad gas or allowed enough moisture to build up and after you washed the moisture accumulated. If you check out the electrics and problem still persists use a gasoline additive. Good Luck.
Old Mar 10, 2010 | 07:59 AM
Gliden's Avatar
Gliden
Default missfire
LOL...OK at least your honest!
How's it doing now as of March 10th.....still missing?
Old Mar 10, 2010 | 09:26 AM
Leftcoaster's Avatar
Leftcoaster
Originally Posted by rscalzo
I wouldn't. Leaf blowers do not filter air so you are drying the bike with dirt laden high speed air.
That's really funny. FYI: When you're joking around like that please add an LOL or grinning icon so we know you're not really serious. LOL
