Can anyone help with a map
Old Mar 19, 2010 | 10:16 PM
hittman's Avatar
hittman
Default Can anyone help with a map
I have a friend who is getting ready to swap out his stock cams for a set of HQ 525 cams. He has a 2009 streetglide with a stage one. He has stock pipes with Rush slip on's. Would some one have a map they would share with him until he can have it properly tuned? If you have one you would share please let me know so I can give you my e-mail address.
Thanks.
Old Mar 19, 2010 | 10:37 PM
Harleypingman's Avatar
Harleypingman
Is he using SEST, PCV, or what? I don't have a map, but that will make a difference.
Try the Head-Quarters forum, also:
http://hqperformance.freeforums.org/...103-t1118.html
There's a good chance someone there has something your buddy could use.
Carl
Old Apr 16, 2010 | 03:57 PM
hittman's Avatar
hittman
He is using a SEST.
Old Apr 16, 2010 | 04:11 PM
doggiedave's Avatar
doggiedave
If you go into the file program on the disc, you will find maps for a lot of applications. you did't state what exhuast, displacement etc. if you look towards the maps for the higher perf combinations it will probably get you into the ballpark, keeping you away from leaning out until you can get it pro-tuned. as a good start whatever map that you down load, I would suggest maxing out the O2 bias which will richen the mixture to some extent with out getting carries away. If you look for Hogdoc on vtwin forums He is a professional tuner in Florida. and quite freindly and helpful
Old Apr 16, 2010 | 08:50 PM
hittman's Avatar
hittman
Thanks doggiedave he has the stock pipes with rush slip ons. He still has stock displacement 96 in along with stock heads. He is just changing the cams. I was hoping someone out there had real close the same set up and had a good map they would share.
Thanks again!
Old Apr 29, 2010 | 10:39 PM
hittman's Avatar
hittman
Bump....
LazySundays
Jul 9, 2019 09:47 AM
Pur3vil
Jul 20, 2018 01:16 AM
rezrider
Nov 28, 2015 07:13 AM
Jeckel
Apr 16, 2015 09:35 AM
supra0001
Apr 16, 2013 05:39 PM
