Changing front levers
Old Mar 29, 2010 | 09:31 PM
clarkchriston's Avatar
clarkchriston
Default Changing front levers
This is just an FYI for those of you who change your front levers.
First - Listen to everyone and put a cardboard paper, or zip tie end or something else behind the lever to save your brake lever pin housing....my membership check is in the mail fellas.
Second - On most newer Harleys there is also a pin under the clutch lever. The pin is basically a dummy switch that prevents the rider from starting the bike in gear without the clutch engaged. Well some aftermarket levers are not as wide behind the housing as the stockers. After replacing my levers I started the bike and rode it for a couple days with no problem....then all of a sudden I would have problems with it starting. After going through replacing the fob batteries, checking the battery for charge, pulling and looking at fuses and relays I decided to call a local indy and he told me of the pin and said to try starting it in neutral. Sure enough works like a charm. The clutch engages just fine so he said forget about it and just start in neutral. He also said starting in neutral is easier on the engine and that i did not know.
Hope this keeps someone else from some beer drinking, head scratchin, bucket kicking, I should be out riding right now, garage time.
Old Mar 29, 2010 | 10:23 PM
Dionicio's Avatar
Dionicio
Good info, Thanks for posting.
Old Mar 29, 2010 | 10:44 PM
chuckb16's Avatar
chuckb16
Good timing on your post. I just changed my levers. If I could add one more piece of info my indy told me. Make sure to leave about an 1/8" on play on the clutch lever so as not to burn the clutch. Thanks for the post. Good info
Old Mar 30, 2010 | 09:48 AM
gmc's Avatar
gmc
It's pretty hard to change the brake lever w something stuck in there, that's only if you are loosening the switch housing which you don't have to do to change the brale lever. Just pull the pin, remove and be careful when replaceing that it is lined up. On the clutch side you do loosen the adjustment in the middle of the cable to get slack needed to slide the end of cable forward out of the housing.
https://www.hdforums.com/forum/touri...t-in-gear.html
Old Apr 14, 2010 | 10:10 AM
Slopneck's Avatar
Slopneck
Great info! I'm about to change mine and I'll heed your advice. Thanks!
Old Apr 14, 2010 | 12:18 PM
Jonny Cannon's Avatar
Jonny Cannon
I would suggest hanging a towel over each lever side when you are removing the little circlip that holds each pin in place. That way, when the little ring slips off of your circlip pliers and fires off into parts unknown, the towel catches it and drops it on the floor in front of you. Ask me how I know this.
Cannon
Old Apr 14, 2010 | 12:35 PM
PhatTerry's Avatar
PhatTerry
Cannon
LOL, sooner or later we all learn that the hard way.
rogersachs
Feb 20, 2014 12:17 PM
Dr Matt
Dec 20, 2010 07:23 AM
douglas07UC
Oct 31, 2009 01:58 PM
rome304
Aug 6, 2009 05:59 PM
CLL375
Aug 14, 2006 04:25 PM
