Can I put a 6 gallon tank on a 5 gallon touring bike?
#91
5 gallon to 6 gallon...... help!!
I would like to put a 6 gallon tank on my 2003 ultra glide and I understand that you have already done this conversation and are willing to share your knowledge on this. I will take any and all of the information you have on this as I put a lot of miles on and although I haven't run out of gas yet I have been on fumes too many times....... thank you and I look forward to hearing from you! Sincerely, Help..... email: rollin5335@aol.com
Last edited by Flames2002; 11-20-2018 at 06:57 AM. Reason: I want to add something
#92
#93
2004 e-glide fuel tank
Hi,
#94
I installed this 7.2 gallon tank on my 2002 Electra Glide. I had to get someone to weld my old fuel pump mount to the the bracket that came with the tank and weld and my old tank's fuel line bung into the bottom of the new tank. Once the finish welding was completed the tank looked like to was a factory tank. The only issue that I have is trying to extend the fuel level float so that the fuel gauge will register the correct amount of fuel in the tank.
Ebay
https://www.ebay.com/itm/192838899565
Ebay
#95
Ebay
Ebay
#96
This is my 2002 Electra Glide project.
7.2 gallon stretched gas tank a 5 in stretched saddlebags.
Demon Cycles on eBay have them for $250. You might have to modify it, depending on your bike model. Thankfully for me my ild tank was damaged and I could just swap out what I needed onto the new tank and then sealed it.
#97
7.2 Gallons. Reading this made my **** hurt.
But seriously, who wouldn't want the capacity?
#99
Very true, some of us have to stop a lot earlier, but can get two stops on a bigger tank! In addition, there are some parts of the world (including the USA in my experience) where gas stations don't always turn up when we most need them!
