Gas tank swap
Old Dec 10, 2015 | 12:30 AM
Nighttrain689's Avatar
Nighttrain689
Default Gas tank swap
I know someone has probably already asked this but I'm not digging here thousands of post to find it. I have a 85 flthc that I would like to ether find the panels to stretch the tank or maybe swap it to a newer tank that is already streched. If I go with a newer tank will it bolt up to the frame in the stock location or will I need to modify the frame
Old Dec 10, 2015 | 05:14 AM
Tom84FXST's Avatar
Tom84FXST
08 tank on an 83...front mount bolts right up...rear mount needs a nutsert, or weld a nut to the frame...easy.
Old Dec 10, 2015 | 05:51 AM
grbrown's Avatar
grbrown
I also have a recent 6 gallon tank, on my '90. The front tank mounts are wider than the frame, so I used spacers between them, one either side. I installed threaded inserts in the frame, under the seat nose, to hold down the rear. I used a Pingel gas tap plus adapter. You will need the tank trim, as per Tom's photo, plus the stuff underneath, to make the filler hole. You can see the details on-line. Obviously you don't need the EFI stuff that fits inside the tank!
Old Dec 11, 2015 | 06:02 PM
Nighttrain689
Are you still using the stock or aftermarket seat for that year or did you have to change it out to a different year.
Old Dec 12, 2015 | 06:20 AM
bagga's Avatar
bagga
is that the original seat from the 83 that's on the sand blast cabinet? you want to sell it? i think it would work on my 85. night train has the same question as i do. tell us about the seat now on the 83.
Old Dec 12, 2015 | 11:45 PM
Tom84FXST's Avatar
Tom84FXST
The seat in the pic is from an 2008 CVO SG...the seat on the blast cabinet is the original 83 seat...if you want it I will sell it...PM for more info
Old Dec 13, 2015 | 05:26 AM
grbrown's Avatar
grbrown
Hi Tom, I'm interested in how you mounted your CVO seat at the rear. Have you retained the rear grab handle and seat mount? Might open up possibilities for my own mods!
deepsea
Ironhead
Oct 22, 2015 07:49 AM
sportyguy69
Oct 18, 2011 03:07 PM
halmc
Ironhead
Apr 28, 2011 08:42 PM
makstv5
Mar 25, 2010 05:03 PM
mwap269
Oct 14, 2009 11:45 AM
