Drive belt will not stay adjusted?
Old 04-12-2010, 07:33 PM
DPete's Avatar
DPete
DPete is offline
Big Kahuna HDF Member
Received 1,729 Likes on 1,302 Posts
Are you holding the axle with one wrench while you tighten the nut with the other so the axle can't turn when you tighten?
Old 04-12-2010, 07:44 PM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 6,532 Likes on 3,348 Posts
I hold the left side with a vise grip while i hammer the **** out of the other side....
Old 04-12-2010, 07:51 PM
ashmarc's Avatar
ashmarc
ashmarc is offline
What he said. Maybe you already know this?
You gotta hold the weld nut in place on the left side while tightening the cone nut on the right side. Any movement at all.......you've got to do it over.
And yes.......your belt will most likely be looser in some locations than others on the rotation of the belt. Adjust from the tightest spot you find.
Old 04-12-2010, 08:37 PM
BLKBAGGER's Avatar
BLKBAGGER
BLKBAGGER is offline
Originally Posted by bigdumbnoitall00
check the motor mounts.
If the motor mounts are going south it wont stay adjusted. That would be the first thing i would check.
Old 04-13-2010, 04:48 AM
katobird's Avatar
katobird
katobird is offline
Don't forget to put a little "sharpie" mark by the welded nub...
After torqued looked to see if it is in the same position.
Does the torque value on the axle remain the same after it's loose?
Rotate the wheel for a minute or 2 and then check the belt in various positions...
or is is flat out really loose?, if so it's got to be the axle and the little welds, or try an extra 19-20lbs on the torque. also you still have the little locking clip for the axle nut?
Old 04-13-2010, 05:25 AM
smokindave's Avatar
smokindave
smokindave is offline
+++1 One of my friends found they were loose.
Old 04-13-2010, 05:29 AM
kyote's Avatar
kyote
kyote is offline
Originally Posted by Wally
They don't use those any more buddy. Haven't since at least 02' maybe earlier.
See what happens when ya ride a "old" bike..lol.. makes ya wonder why they did away with em now don't it??
Old 04-13-2010, 06:11 AM
Sandcrab's Avatar
Sandcrab
Sandcrab is offline
Default air or ground
Are you doing it with the wheel raised up off the ground, or on the jiffy stand??? Made a difference on mine.
Alain
10-07-2012 08:43 PM
mang0
04-06-2011 05:11 PM
RocketRocker
11-18-2009 09:31 PM
Doug S
06-12-2009 11:13 AM
jrsmith_80
08-05-2008 04:54 PM
Quick Reply: Drive belt will not stay adjusted?
