Primary Service ???
Old Apr 29, 2010 | 04:36 PM
Glyder's Avatar
Glyder
It'll take 38oz in an 07 and up if its completely dry like if youve had the primary cover off....32oz will do you just fine. That chain will be slingin plenty of oil around with just 32 oz.
Old Apr 29, 2010 | 05:29 PM
BlackFLHR's Avatar
BlackFLHR
Not correct either... So much mis-information.
Taken directly from the Service Manual for 2009 Touring models:
Pour 38 fl. oz. (1124 ml) of GENUINE Harley-Davidson
FORMULA+ TRANSMISSION AND PRIMARY CHAINCASE
LUBRICANT (Part No. 99851-05 quart) through the
clutch inspection cover opening.
NOTE
Only add 45 fl. oz. (1331 ml) after service that involves removal
of the primary chaincase or primary chaincase cover.
Old Apr 29, 2010 | 05:40 PM
mcfarland1286's Avatar
mcfarland1286
Hey all.... thanks for the info... just wanted to make sure I needed two quarts before I placed my order....
and I have an 09 Ultra... sorry I didnt mention that ion the original post...
Thanks again
Old Apr 29, 2010 | 06:50 PM
Conehead's Avatar
Conehead
That was what my dealer said as well when I tried to buy 2 quarts because I knew it said 38 ounces.
Old Apr 29, 2010 | 07:05 PM
NoCoLoco's Avatar
NoCoLoco
My manual says 45oz if it's completely dry, 38oz if it's just a drain and fill.
Old Apr 29, 2010 | 08:15 PM
voodoodrug's Avatar
voodoodrug
its been awhile but i think the manuel contradicts itself,ive seen it but cant remeber exactly,,,i just filler up as discribed and its about 38 oz fluid drams,adracnums..ect
Old Apr 29, 2010 | 08:27 PM
ripper43's Avatar
ripper43
The manual says 38 oz. so go with that and you can't go wrong. Every Mechanic, Dealer, Service Mgr and Joe Stroke told me 32 oz is what they do and it is fine. so that is what I do.
Old Apr 29, 2010 | 08:33 PM
Glyder's Avatar
Glyder
How about just do what it says period and fill it up to the bottom of the clutch basket.......and ounces be danged!
dirty 3rdy
Jul 9, 2011 01:18 PM
2007ELECTRICGLIDE
Apr 30, 2011 08:24 AM
jsciullo
Aug 16, 2010 11:33 PM
freebyrd
Oil Archive (no new posts)
May 27, 2008 08:59 AM
gels55
Nov 15, 2007 05:23 PM
