Need audio help
Old Apr 29, 2010 | 09:28 AM
Astro's Avatar
Astro
Default Need audio help
My wife was riding with me Sunday and pointed out that my right rear speaker was not working. I don't have any idea how long it hasn't been working as I don't get much sound up front from them.
I switched them out from right to left and the right speaker still doesn't work. That eliminates the speaker itself. Any ideas as to what is wrong? Is it possible for one channel to go bad in the radio?
Thanks for the help in advance!
Don
Old Apr 29, 2010 | 10:10 AM
Harleypingman's Avatar
Harleypingman
What model and year bike do you have?
Old Apr 29, 2010 | 10:34 AM
Big Gee's Avatar
Big Gee
Sounds like a bad connection along the line somewhere. Best thing to do is start from the speaker and work back towards the head unit and check each connection as you go.
Old Apr 29, 2010 | 11:00 AM
Astro's Avatar
Astro
The bike is a 2007 Ultra Classic.
There are no connections between the radio and the speaker.
The harness comes out of the back of the radio, under the tank, under the seat to the rear speaker pod. All along the way it is wrapped in one and some places two plastic wraps.
Old Apr 29, 2010 | 11:06 AM
SG Mike's Avatar
SG Mike
You either have a short in the speaker wire (unlikely but possible). Or the radio is bad (More likely).
Get a DVM and check your wires for shorts if no short then your Radio is bad.
Old Apr 29, 2010 | 11:07 AM
Harleypingman
Use this procedure from the HD2007 Electrical Diagnostic Manual to access your radio's diagnostic display:
"Press the eject button to remove any CD that might be in the
unit. Then, while depressing and holding any two softkeys
(buttons 1-6), turn the ignition switch to ON. Once the H-D
logo is displayed, the system automatically performs a
complete switch check, scans for current DTCs, and then
displays the radio diagnostic display. Release the softkeys
only after the radio diagnostic display appears."
If there are any trouble codes, the screen will display the code and brief description of the problem. HTH.
Carl
Old Apr 29, 2010 | 12:10 PM
jmorganroadglide's Avatar
jmorganroadglide
Big Kahuna HDF Member
girlfriends don't notice as much a wives
Old Apr 29, 2010 | 12:26 PM
Astro's Avatar
Astro
Carl,
Thanks!
I got a code that says the "FR Speaker Open"
Sounds like a problem with the radio.
Thanks for steering me in the right direction!
Don
Old Apr 29, 2010 | 12:27 PM
Astro's Avatar
Astro
Very true.
If I was carrying the girlfriend I probably wouldn't notice the speaker either!
Old Apr 29, 2010 | 03:14 PM
Harleypingman
Originally Posted by Astro
Carl,
Thanks!
Don
You're welcome, Don.
