I've read many posts about installing the amps on the forum. Most guys say you'll need to remove the gas tank to run the power wire to battery. I really hate to do that and was thinking about removing the chrome console on top of the tank and running the power wire through there. Two other sets of wires are already running through there and these wires dump right into battery area.
Any reason why I could do this??
Lots of great info here on the subject of amps. Thanks to all you who have posted pics and installation instructions already.
First off, the consol idea is risky and not a good idea in my opinion. You do not have to remove the gas tank either. You can actually just lift the gas tank about 1/4" to 1/2" and run the power cable under the back bone without any binding or squishing after you drop the gas tank back into position. I would make sure that the power cable is double insulated for added peace of mind. Just add another layer of shrink wrap or plastic to the main power cable where it goes under the tank.
The existing wires that you were talking about, seem like an ok idea too. Is the power side fused?
I won't respond again until this evening. Sorry ahead of time.
Originally Posted by banks727
I'm installing my new Elf amp with J&M's 7.25's.
I ran 3 - 18 gauge wires up through the main wiring harness trough to the inner fairing. I used a straightened out coat hanger and "gently" fished it through.
Yes I initially ran my power and ground wire under tank console it's ok. I later removed my tank and ran them through wiring harness trough. The '09 tank is easy to remove as it has a quick disconnect on the gas line.
Run the wires under the tank. The tank is easy to lift/remove and HD provides troughs for the wires. If you run them under the tank, it's pita to reinstall the tank console and gasket/edging along the base. You'll also have wires exiting out the front/bottom of the tank console which can be a problem for you cosmetically.
The wires under the tank console have to be there for the fuel pump; otherwise all wiring is run under the tank.
Thanks guys. Great ideas. I'm just worried about leaking gas all over. I've read so many posts of guys having trouble with the crossover leaking as you have to cut it.
I liked the idea of just lifting the tank and running the wire under there with an extra layer of around it.
One question.... When removing the 09 tank. How would I cap off the fuel line? Or can I leave it connected and just move tank to run the wire and set it back down?
I really appreciate the help!! Guys on this board are so helpful. Kind of reminds me of the military.
On a 09' where fuel line enters tank push up on the chrome sleeve(top)and pull down on fuel supply line to disconnect. Very little gas will spill. Just make sure your tank is low on gas for sake of lighter tank to lift off.
No gas leak. No crossover on an '09. Its very easy to remove the tank. Just run it low so its light. Open the trough and run the wires through and do it right.
Great advice guys. I'll plan to try to raise the tank a bit, or remove it if that doesn't work. I'll run the power wire under it.
Can't wait to get this amp in. I've heard so many good comments about the J&M's with an amp. Hope this one is near as good as the J&M amp is suppose to sound.
