Quick Question
Old May 6, 2010 | 08:44 AM
tangeloglide's Avatar
tangeloglide
Default Quick Question
I have a well nut for the windshield which keeps pulling out. Is it ok to glue the well nut into the fairing?
Old May 6, 2010 | 08:50 AM
SoCalRoadGlide's Avatar
SoCalRoadGlide
I had the same problem with mine. It turned out that a couple of the holes that the well nuts sit in had worn into an obround shape, due to vibration. I epoxied 3/8" flat washers on the backside of the holes. I also got some well nuts off ebay that have a larger, for lack of a better description, mounting pad. I'm talking about the part of the well nut that the windshield actually sits on. I haven't had a problem since.
Old May 6, 2010 | 08:56 AM
Olde Skool's Avatar
Olde Skool
The dealers have a repair kit where the new brass inserts have threads on the outside and cut threads in the plastic. No idea what the part number is. Give them a ring, they will know what yer asking about...
Old May 6, 2010 | 09:02 AM
mariner227's Avatar
mariner227
The part number for the new inserts is 16585-96. This number was for my ultra, should be the same for your rg. I would not glue it. The slots in the insert goes in to the fairing. It is not for a screw driver. ( ask me how I know this }
Old May 6, 2010 | 09:05 AM
FXSTS-88's Avatar
FXSTS-88
Just get some 5-minute epoxy and glue the sucker back into the hole.
Did that on a friend's older bike and it's still holding.
Don't over tighten the screws when you reinstall them.
Old May 6, 2010 | 11:58 AM
tangeloglide
Thanks all for the great input. Looks like I'll go get the repair kit.
Old May 6, 2010 | 12:00 PM
JustDennis's Avatar
JustDennis
They are just threaded brass inserts. Use a bolt with 2 nuts on it threaded into the insert to screw it into the fairing. The slot end goes in first.
Old May 6, 2010 | 12:18 PM
BezerkoBob's Avatar
BezerkoBob
I had one come out on my Ultra. Like FXSTS-88 did, I just epoxied mine back in. That was over a year and have not had any problems since. Not sure what the repair kit cost is from HD but I already had the epoxy at home.
Old May 7, 2010 | 12:08 AM
rideon's Avatar
rideon
You have a road glide with rubber wellnuts, batwing fairings have brass inserts and are NOT interchangeable. Go get yourself some new well nuts and all will be golden!
Old May 7, 2010 | 12:15 AM
Dan1127's Avatar
Dan1127
Default Great info
Just what I was looking for. You all know why.
