screamin eagle slipons
Old May 20, 2010 | 10:02 AM
ricaroo's Avatar
ricaroo
Default screamin eagle slipons
I put a set of Screamin Eagle slipon mufflers on my 08 ultra, now I get a slight vibration in the floor boards. is this normal?
I had stock mufflers on the bike before and did not have the vibration.
Any ideas...
Old May 20, 2010 | 02:29 PM
JONNIEROCK's Avatar
JONNIEROCK
If you don't have the pipes on straight, and they can't slide back and forth in the rear rubber mounts under the saddle bags, they will cause vibrations. Hope this helps JONNIEROCK
Old May 20, 2010 | 05:10 PM
ricaroo's Avatar
ricaroo
they went on fairly easy, however how can you tell if they are straight? they look good by eye
Old May 21, 2010 | 08:27 AM
ricaroo's Avatar
ricaroo
Bump ?
Old May 21, 2010 | 08:37 AM
Seminolebagger's Avatar
Seminolebagger
If the exhaust system comes in contact with the frame at any point, it will transfer vibration. It doesn't take much contact.
Old May 21, 2010 | 08:47 AM
RKCUSTOMBUD's Avatar
RKCUSTOMBUD
Ric, one of my rules for trouble-shooting problems is : if you didn't have a problem before you changed something, then the problem is almost always associated with the change you made. Double check everything, there is something loose or as was said above, when engine vibrates, some where on your new slip-ons, they are touching something. You will see it, it just might take a while.
Old May 23, 2010 | 06:24 PM
ricaroo's Avatar
ricaroo
I completly removed the exhaust system and re-installed it, paying close attention to be certian that nothing hit the frame and the mufflers were installed straight. I still get a vibration in the floor boards and the highway pegs.
No vibration in the seat
Any thoughts?
Old May 23, 2010 | 08:13 PM
FLS2FLH's Avatar
FLS2FLH
Re-install the stockers one at a time and see if you can narrow it down.
Old May 24, 2010 | 07:52 AM
ricaroo's Avatar
ricaroo
Bump ?
crazykev4x4
Touring Parts
Nov 5, 2016 10:40 AM
KEYBEAR
Aug 5, 2013 08:59 PM
RadarRider
Jun 15, 2010 10:50 PM
gkvette
Dec 28, 2008 03:26 PM
streetglider
May 19, 2006 10:39 AM
