Decel Backfire
Old Jun 7, 2010 | 06:43 PM
Docolade's Avatar
Docolade
Stage I
Default Decel Backfire
I am riding a 2001 ultra classic injected. Am not original owner and don't know for sure what after market pipes I have. They are slash-cut ovals and have been told they may be "Hookers" When the engine gets hot, it backfires on decel. I have installed a power commander and have tried 3 different maps but problem continues. The hog runs like a top and I can live with the backfire but would like to correct if I can. Any thoughts or experience anyone has would be appreciated. Also am wondering if it would be worth the expense to change rims so I could run tubless tires.
Thanks.
Old Jun 7, 2010 | 07:20 PM
Dustball's Avatar
Dustball
I have the Hooker Tuned Flows -- killer mufflers with adjustable back pressure. When I come off the gas with the revs up she pops and crackles too, but nothing to be concerned about providing she's not running overly lean. I happen to like the sound.
FYI - Check your muffler clamps just in case; air leakings ahead of the mufflers creates popping too.
Old Jun 7, 2010 | 07:29 PM
FLoTR's Avatar
FLoTR
[quote=Dustball;6828060] When I come off the gas with the revs up she pops and crackles too, but nothing to be concerned about providing she's not running overly lean. I happen to like the sound. quote]
My ThunderHeader does it too. I figure thats where the name comes from, and I too like the boom boom boom.....
dawg's Avatar
dawg
Check for intake leaks, check for exhaust leaks.
Old Jun 7, 2010 | 08:50 PM
Harley58's Avatar
Harley58
My '01 Injected Ultra does the same thing. I have the Fuel Moto Package with the jackpots. Doesn't seem to do it when it is really cool outside. Did it worse before the fuel package upgrade.
Old Jun 7, 2010 | 08:54 PM
AR-15 DEUCE's Avatar
AR-15 DEUCE
When I had stock pipes,mine would always backfire,I put on my VH and wallahh no backfire..
Old Jun 7, 2010 | 08:56 PM
RidemyEVO's Avatar
RidemyEVO
Perhaps the timeing is a bit too advanced.
Old Jun 7, 2010 | 09:29 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
imguessin exhaust or intake leak.check the easy stuff first.
Old Jun 7, 2010 | 10:25 PM
RAP's Avatar
RAP
If your power commander is the same I had on my 05 ultra, you should be able to adjust that out with the small buttons on the commander. Mine did the same thing and after reading the directions, I adjusted the buttons and it was gone.
Old Jun 7, 2010 | 10:43 PM
terrible1one3's Avatar
terrible1one3
It's all in the tuning.
Decel pop is a cause of high engine RPM (as opposed to idle) and throttle position being at zero.
With stock pipes and tune the fuel injection is pretty well tuned and decel pop for the most part is a rarity.
When you open up intake or exhaust or both you change this. HD "Download" tunes or Power commanders aren't a "dyno tune" thus they are close but not perfect.
One way to for sure get rid of it is a HD Race Tune from a PROPERLY TRAINED technician. This requires the proper dyno, sniffers, and a process.
Mainly there are two ways the decel pop can be tuned out, tune it to dump extra fuel at 0% throttle or lean it out considerably. The ladder is normal.
Apparently you can do this with the power commanders and what not but best way, is a good race tune!
