primary question
Old Jun 23, 2010 | 10:53 AM
rjones1891's Avatar
rjones1891
Default primary question
i have a 2010 road king just wondering is the primary self adjusting did a search did not see the answer
JustDave71's Avatar
JustDave71
pretty sure all recent models have automatic chain tensioners. That's what you're asking, right?
Old Jun 23, 2010 | 10:55 AM
doggiedave's Avatar
doggiedave
I believe self adjusters started in 06' your 10' model has an auto adjuster for sure
Old Jun 23, 2010 | 11:02 AM
Jackie Paper's Avatar
Jackie Paper
Default Adjust
If you look at the primary cover you will see the large removable right cover. That is the clutch cover. (derby cover) Centered there is a long depression with no cover. Harley quit putting a cover there when they put the self adjuster in. My 04 has a cover there and really older bike, not sure of year, have a cover to the left over the compensator primary drive to turn engine over manually while working on it. Does anyone out there know when this cover went away and other uses for it?
Old Jun 23, 2010 | 11:05 AM
rjones1891's Avatar
rjones1891
thanks that what i was wanting to know
Old Jun 23, 2010 | 11:22 AM
krazy3's Avatar
krazy3
Yep and you are lucky enough to have the 'new redesigned' tensioner that my '07 didn't, but does now.
Old Jun 23, 2010 | 12:45 PM
Jackie Paper
Default Adjustment
You appear to have had a lot of bikes. Do you own adjusting? From my experience, due to the fact that the old style manual adjuster has a roller chain going over it , once the links groove it and the chain starts rolling there is little wear. In fact my chain stayed in adjustment for the last 30K. Little loose from run out in one position but still in the range but the next step up on the adjustment was too tight
Old Jun 23, 2010 | 08:53 PM
rjones1891's Avatar
rjones1891
thanks for the post haven't worked on any of the two Harley's than i have owned just let the dealer do the Service on them trying to learn before i do it looking forward to serviceing my road king myself soon
Old Jun 24, 2010 | 07:48 AM
dog155's Avatar
dog155
Yes they are,just have to check the slipper shoe every once in a while,and make ssure the mechanisim is working properly.
Old Jun 24, 2010 | 09:02 AM
Jackie Paper
Default Check slipper shoe
How do you do that.?? Reach in thru the clutch cover and insure there is a slight amount of slack in primary chain (about 5/8-3/4") but not too much (over an 1") cold. Maybe 1/8-1/4" less then those figures when hot
