Front end noise
Old Jun 24, 2010 | 11:13 AM
cayers's Avatar
cayers
Default Front end noise
Last week I notice a metallic clicking coming from the front end of my 05 Ultra while pushing it out of the garage, first thought was the wheel bearings were going out.
I didn't ride since then, yesterday a friend and I put on the floor jack to check it out. With the front wheel off the ground we gave it a spin and sure enough we heard the "noise". After further inspection of the wheel area, we found that one of the retaining clips for the fender light wire had lost it's grip and was touching the tire. The raised lettering was causing the clip to be flipped out hitting the inside of the fender.
We took off the front tire and found an four more additional clips that the weren't being used. Put the wire in the clips and they are holding for now.
The clips are held on with thin double sided tape(gotta be something better) and I want to replace all of the tape on all of the clips so this doesn't occur again. I have never seen any double sided tape that thin before. Is this a dealer item and if not where can I get it?
Has anybody else experienced this? If so what did you do?
Thanks in advance!
Cecil
PS....just freaking happy it weren't the wheel bearings
Old Jun 24, 2010 | 06:00 PM
dawg's Avatar
dawg
10102 is the pn# for the adhesive backed clips $1.75 each. Make sure the fender area underneath is cleaned very well prior to attaching these.
Old Jun 25, 2010 | 08:45 AM
cayers's Avatar
cayers
Dawg,
Thanks! I suppose that includes the actual clip also, not just the tape.
Thanks again!
RomeoTango
Oct 23, 2017 09:33 AM
cpudoc
Jun 4, 2017 01:37 PM
RG462
Oct 23, 2010 07:30 AM
Da Butcher
Jul 14, 2009 08:56 PM
fishafly
Sep 22, 2007 10:54 PM
