I need power
Old Jul 3, 2010 | 10:37 AM
ToyjoHa's Avatar
ToyjoHa
Default I need power
Can someone direct me what can be done to increase power to my stock twin 88 for under $1000?
Old Jul 3, 2010 | 10:42 AM
mongomark's Avatar
mongomark
Do you have any exhaust mods or anything with your aircleaner? Are you completely stock? Step 1 would likely be stage 1.
Old Jul 3, 2010 | 10:51 AM
strtarrow's Avatar
strtarrow
I have the SE Heavy Breather and the ad claims 10 HP gain for my 01 and +12 for later models. Don't believe it but it does look great IMO.
Old Jul 3, 2010 | 11:01 AM
Road Ranger's Avatar
Road Ranger
If you can do your own work you can get a cam kit for around 800 but then you'll need a tune...or you can give jamie over at fuelmoto a call and see what he suggests.
Old Jul 3, 2010 | 11:03 AM
dawg's Avatar
dawg
Ness Big Sucker = $120
Rush slip ons = $400
TTS Mastertune = $425
Then next year go for cams and 95 kit and do the work yourself and you'll be under $1k also.
Old Jul 3, 2010 | 12:50 PM
akroguy's Avatar
akroguy
Get a better air filter, a set of slip ons, or if you really want cheap, punch out the center baffles in your stock cans.
Then, a power commander III from Fuel Moto and you WILL feel a difference.
Next, cams and cam plate/tensioner upgrade. Your motor has the spring tensioners and they are a ticking time bomb. When they go, so does your oil pump and maybe more. My spring tensioners were looking really bad at 29K miles when I pulled them a couple days ago.
95" big bore kit can be done too. I'm tearing into the engine and doing the jugs and cams at the same time. I'm cleaning/replacing seals and various little bits here and there as I go. I didn't buy everything at once, just started a year ago acquiring various kits. Check Ebay for big bore and cam plate upgrade kits. Zanotti's HD online for OEM and SE parts at a discount.
Old Jul 3, 2010 | 04:57 PM
nvsteve's Avatar
nvsteve
You can do it easily under $1000 with a power package from Fuelmoto. If it's not enough extra power for you, you haven't wasted money. It's stuff needed anyway.
Old Jul 3, 2010 | 05:29 PM
carpetride's Avatar
carpetride
Heck with that stage 1 garbage.
For $1279 you can make some REAL power.
http://www.tejasthumpcycles.com/Part...ide.System.htm
(you might be able to negotiate a discount and get closer to $1000)
Old Jul 4, 2010 | 12:44 PM
harry.b's Avatar
harry.b
Whatever you decide, make sure that the mods are good for future upgrades if you are on the fence about doing them. For instance, if you decide to go to a 113" in the future that requires timing adjustments, then a PCIII may not be the best choice. I did the stage 1 and it wasn't enough, so now I have a PCIII for sale. Probably cost me $200.00 in the long run assuming I can sell the PCIII. As far as an upgrade that will get you more power, there are alot of choices and tons of info on the site. I was happy with my choice for stage 1 in sig below. I think someone has the fever!!!! Good luck with your mod.
harry
Old Jul 4, 2010 | 05:01 PM
ToyjoHa's Avatar
ToyjoHa
Sorry, I forgot to mention that I already have stage I
