Fixed antenna relocation reception problem
Old Aug 29, 2006 | 10:59 PM
ragingbull's Avatar
ragingbull
Default Fixed antenna relocation reception problem
I had the mounts for a removable tourpak with the antenna relocation kit put on my Street Glide. Afterwards I could only pick up one of my regular stations in Los Angeles. Before the relocation kit I got good reception on all stations. After tightening everything and not getting any better I started to look at how all the plugs went together. The large adaptor that goes into the relocation bracket was the problem. It has lock nuts above and below the adaptor plate. The upper lock nut only allowed the upper cable jack to screw down 2 threads. This wasn't deep enough to contact the inner antenna surface. It really only needs the bottom lock nut anyway so I took the upper off and now I've got what sounds like better reception than before. If you wanted to retain the upper lock nut I've seen thinner lock nuts but haven't done a search for them yet. The next step is cutting the antenna down some but I'm definitely happy with the results so far...
Old Aug 30, 2006 | 10:23 AM
hduc2005's Avatar
hduc2005
Default RE: Fixed antenna relocation reception problem
thanks for the info I am putting one of these on next week.
GalvTexGuy
2014-2024 Touring Models
Jul 2, 2015 08:54 AM
roussfam
Audio Systems
Jun 8, 2014 06:11 PM
ReilandLaw
Nov 28, 2012 09:25 AM
drumaniak
Apr 22, 2008 09:35 AM
ragingbull
Aug 22, 2006 07:22 PM
