fuel moto power commander install?
i just had a friend take there RKC to a indy and had a power comander installed and dyno..cost them @ 650.00 with a K&W air filter and new plugs..my question is this, can a power commander purchased from fuel motto for @ 260.00 be easly installed and the setting set to run cooler,smoother,less decel popping, by the average person with average mechanical skills..or is this somthing better left to the pros?
thanks in advance
thanks in advance
In a word, yes. And the customer service at Fuel Moto is second to none. I had a problem with my autotune that I could not figure out on my own, and I'm a fairly competant shadetree mechanic. Jamie figured out what the problem was, and helped me get it completely sorted out.
If you're just going to install a Power Commander, there is only one place I'd buy it from. The lifetime map support is worth what you're going to pay for the power commander.
Most cavemen are smarter than me and I just installed the FM PCV and the FM air cleaner. I also installed new wires and plugs. Total time of about an hour. Went out for a test ride and had a minor problem with the map Jamie pre-loaded for me. Called them the next business day and spoke to Jamie and 15 min. later I had a new map loaded and was out riding with no problems at all. Wish I'd done it sooner. Fuel Moto is an excellent company.
thanks in advance
thanks in advance
Have at it man!
Seriously - if you have unplugged a lamp in your house you can do this job... it's pretty much the same thing.
1. take off the side cover
2. unplug the ECU
3. Plug the power commander into what you just unplugged.
4. wire-tie and or use the double sided tape to stash the PC under the cover.
You are done... and you WILL be happy.
2. unplug the ECU
