Mobil one synthetic oil
Old 08-06-2010, 12:18 AM
merkinman's Avatar
merkinman
merkinman is offline
Question Mobil one synthetic oil
Is there any difference between mobil 1 reg oil and Mobil one V twin oil. The v twin oil label says four stroke motor cycle oil What does it matter Mobil one or Mobil one cycle oil
Old 08-06-2010, 05:17 AM
VETERAN75's Avatar
VETERAN75
VETERAN75 is offline
Yes there is a difference. The vtwin oil is formulated for air cooled engines. It is also similar to a diesel oil. Check the sf, cf ratings on each one. There you will find a difference.
Old 08-06-2010, 05:40 AM
kingkingking's Avatar
kingkingking
kingkingking is offline
Mobil 1 V twin is much more expensive. Thats the main difference.
The below stats show that the oils are essentially the same. Mobil 1 15/50 actually has higher specification than Mobil 1 V twin.
Mobil 1 V-Twin 20W-50:
API SG,SH,SJ/CF
JASO MA
Typical Properties
SAE Grade 20W-50
Viscosity, ASTM D 445
cSt @ 40ºC 130
cSt @ 100ºC 17.8
Viscosity Index, ASTM D 2270 150
Sulfated Ash, wt%, ASTM D 874 1.0
Pour Point, ºC, ASTM D 97 -51
Flash Point, ºC, ASTM D 92 270
Density @15 ºC kg/l, ASTM D 4052 0.897
Mobil 1 15W-50:
API SM/SL/SJ/CF X
ACEA A3/B3 X
A3/B4 X
Typical Properties
Mobil 1 15W-50 Value
cSt @ 40º C 124.1
cSt @ 100º C 18.0
Sulfated Ash, wt%, ASTM D 874 1.4
Phosphorous 0.1
Flash Point, ºC, ASTM D 92 229
Density @15º C kg/l, ASTM D 4052 0.86
Total Base Number (TBN) 11.9
MRV at -40ºC 12188
Viscosity Index 161
HTHS Viscosity, mPa•s @ 150ºC, ASTM D 4683 5.0
Old 08-06-2010, 05:41 AM
Drtumolo's Avatar
Drtumolo
Drtumolo is offline
normal mobile 1 has a friction modifier in it. I used it once in a Jap bike and cause clutch slipping.
Old 08-06-2010, 06:23 AM
oscarg's Avatar
oscarg
oscarg is offline
V twin dosn't have friction modifiers added which can affect clutch performance
Old 08-06-2010, 07:20 AM
Motorboatn SOB's Avatar
Motorboatn SOB
Motorboatn SOB is offline
I've using 15W 50 in the crankcase for 17,000 miles with no issues. The v-twin is formulated for bikes that use common oil (same reservoir) for crankcase, primary, and tranny. HD uses separate oil for all 3. I wouldn't use it for the primary for the reasons in the post above. I wouldn't use any synthetic in the primary (waste of money). Just my 2 cents. Do what makes you feel comfortable.
The following 2 users liked this post by Motorboatn SOB:
Jehu (08-16-2019), vizcarmb (08-16-2019)
Old 08-06-2010, 07:29 AM
nvsteve's Avatar
nvsteve
nvsteve is offline
Everything I've read says regular Mobil 1 is fine for the motor. Have seen lab tests that say it's fine. Not recommended for primary tho.
Some Walmarts have 5 qt. jugs for $21.
Old 08-06-2010, 07:31 AM
soos's Avatar
soos
soos is offline
I agree. I use 15W-50 in the crank and use Castrol GTX10-40 Dino in the primary. Using a synthetic in the primary is simply a waste of money.
Old 08-06-2010, 10:08 AM
huffhuff's Avatar
huffhuff
huffhuff is offline
there is not enough difference in the additives to pay the extra cost. I had 69K on my 01 RK when i traded it on my 09. 15W50 went into it at the first change at 500 miles.
i had it apart at 54K for gear drive cams everything looked new. my 09 got it at 500 miles too. i ran synthetic ATF in my 01 from new and am doing the same in my 09. ATF is formulated for clutches (obviously).
Old 08-06-2010, 11:01 AM
Scorpion07's Avatar
Scorpion07
Scorpion07 is offline
Yup - about $5 / qt!!!
Other then that - it's a dark science that we layman wouldn't understand.
And frankly marketing has as much to do with it as true science.
I've read quite a few tests over the years, and question the real world viability of most of them. You always have to question who paid for the tests.
If there really was a "best" oil (other then SAE ratings) I think we'd have a definitive answer!
That said - I've been running Mobil 1 V-twin for 40K miles in my engine!
You rarely hear of oil related failures these day's, so why do we fall for the hype??
Quick Reply: Mobil one synthetic oil
