Thanks for the cable lube suggestions. I am using Magnum cables so I wasn't sure they were pre-lubed. Any suggestions for a good grease for greasing the lever friction points? I just don't want to use something that will make a mess when they get warm.
Disconnect the cable from the lever, cut the ties and lay it out flat on the ground.
When fluid comes out the lever end.....it is lubed.
May take a few hours.
If it is Teflon coated, do not lube the cable. If it is not Teflon coated, dri slide is hard to beat.
Your post prompted me to check Magnum's site which if my brain was working when I posted I would have checked first. The cables are pre-lubed and have a teflon sleeve. This tells me that I don't need to worry about it for a while. Sorry for wasting time on this and thanks for the replies.
