glide pro stabilizing unit
Old Sep 17, 2010 | 10:44 PM
bagman1's Avatar
bagman1
Did you install the stock height kit? If so how many plastic clips did you put in to set the preload? I did 1 clip and although it rides smoother over little bumps (hiway dots) the steering is over sensitive at idling or tight lock to lock turns. Progressive suggested I take the one clip out and that would lesson the preload and make the front end less sensitive.
Old Sep 18, 2010 | 10:38 AM
BigDaddyOC's Avatar
BigDaddyOC
yea I did the stock 2500 kit with both clips. I wanted to lower it 1" since I have a 21" front but with my size I can't, I already lightly kissed the front fender once under hard braking. Thats part of my reasoning of doing the Arnott Alden setup, I'm going with the 13" kit. My hopes is that when I'm riding I air it up to the full 13" and level it back out to compensate for the front and that puts the geometry back in line. That and the fact that with the wife and some gear I tagged the rear seat pin once and buzzed the tire, I figure I'm better off with some extra room out back. Then I can drop it down riding solo or all the way out when its sitting.
hd4l
Jun 19, 2014 11:19 PM
MOTOX56
Oct 19, 2012 02:17 PM
CT 06 glide
Mar 18, 2010 11:13 PM
arthur
Sep 20, 2008 03:25 PM
Primo
Jan 15, 2006 06:52 PM
