glide pro stabilizer
Old Apr 1, 2014 | 09:04 PM
hd4l's Avatar
hd4l
Default glide pro stabilizer
Does anyone have any experience with this system?I just heard of them the other day and they seem like an option as a stabilizer because I cant run the tru-trac with my new s&s power tune dual exhaust.
Old Apr 1, 2014 | 10:38 PM
user 8373900's Avatar
user 8373900
Give the Bagger Brace a look. I had one and it worked great!
Mark
Old Apr 2, 2014 | 12:06 PM
bigheadted's Avatar
bigheadted
Install the Glide Pro set up and you will be fixing the root cause of the problem and not need any band aid brace.
I installed several on mine and buddies bikes and actually have the newest setup on the bench for my current bike. You will notice a very positive difference when you pull out the driveway.
Old Apr 2, 2014 | 01:10 PM
fabrik8r's Avatar
fabrik8r
Put it on, too much vibration translated to the chassis, took it back off, and went back to Sta-Bo, cheaper, simpler, equally effective without the vibes. Get the front motor mount as well.
Old Apr 2, 2014 | 01:52 PM
bigheadted's Avatar
bigheadted
Never had such an increase in vibes it was bothersome, had a very slight increase but it either wet away or I got used to it.
How much increase are we talking here?
Old Apr 2, 2014 | 03:19 PM
AnotherBlackSG's Avatar
AnotherBlackSG
I changed my stock front motor mount with a glide pro and the difference in vibration was HUGE (much less). Some day I may install the rest of the system, but right now I'm happy with just the front mount.
Old Apr 2, 2014 | 03:30 PM
bagman1's Avatar
bagman1
I had the same issue at first with the vibe, the cure is to leave the front mount loose fire up the bike after its warmed up and give it a couple 2k rpm revs than shut it down after it settles then torque the bolt to 10-12 foot lbs. they are expensive though. Be sure you ask for the new style rear bushings if you buy that set.
Old Apr 2, 2014 | 04:43 PM
fabrik8r's Avatar
fabrik8r
More than I was willing to live with.
Old Apr 2, 2014 | 04:51 PM
fabrik8r's Avatar
fabrik8r
I didn't just slap it on and pull it off. I went through the "procedure", called for assistance, went through it several more times, with the lower recommended torque for the install, even made a custom stepped alignment tool to ensure the bolt was perfectly centered and not "binding", it was done beyond correctly, and I rode it for a while to give it a chance. My guess is few people have used both products on the same bike like myself, we only know what we know, I know both, I prefer the Sta-Bo.
Old Apr 2, 2014 | 09:02 PM
hd4l's Avatar
hd4l
Is it better to do the front mount too or is it ok to do just the swingarm bushings?
