STABIL Does it Get OLD?
Old Nov 28, 2010 | 05:10 PM
legendzzz's Avatar
legendzzz
Default STABIL Does it Get OLD?
I have a 5 year old Stabil and used it on the bike for this winter. Bike was spitting and the idle was a little irratic ? Can the Stabil be bad ?
Old Nov 28, 2010 | 05:13 PM
Dionicio's Avatar
Dionicio
I've never had any problems with it, however it states on the bottle thats it good for two years after opening.
Scratt's Avatar
Scratt
Stabil tells you to leave it in the carb but if you do that it can clog it and I had to re-build 3 dirt bike carbs because of it. I don't know if it can go bad but I won't ever leave it in the carb again. I put it in the tank shut off the fuel and drain the rest.
Old Nov 28, 2010 | 05:32 PM
Aslan's Avatar
Aslan
I just took a look at a bottle and that's what it says.
Good for two years after opening.
Old Nov 28, 2010 | 06:07 PM
jmacdonald5's Avatar
jmacdonald5
....that's why you need "Stabil stabil"...
Guntoter's Avatar
Guntoter
I usually use Stabil, but some years I have not and have not had any problems. I am not convinced that Stabil is necessary in a bike sitting only 4 to 5 months. Gasoline does not usually go bad that quickly.
Old Nov 28, 2010 | 06:15 PM
SpiderPig's Avatar
SpiderPig
Somewhere I have read that if Stabil starts to turn a darker color than the bright red that it was when you opened it. It needs to be tossed.
Old Nov 28, 2010 | 07:10 PM
rambler43's Avatar
rambler43
I've had trouble with Stable so i switched to SeaFoam and found that it works much better.
I also talked to a auto parts salesman and he said stable is petroleum based and in time will gum things up.
Old Nov 28, 2010 | 07:22 PM
Estil's Avatar
Estil
Stabil is 5 years old..........spring for a new bottle. Just sayin..
Old Nov 28, 2010 | 08:01 PM
rags-46's Avatar
rags-46
in a fuel injected bike I wouldn't take a chance, get a new bottle. Cheap insurance.
