EFI Tuning Modules
Old Jan 5, 2011 | 04:23 PM
griffy's Avatar
griffy
Default EFI Tuning Modules
Got a 2007 Ultra bone stock. I know they run a little hot from a factory lean setting. Can you use any of the tuning modules on the market I.E. PCiii, fuel pak etc. to enrich the fuel mix a little. My Ultra runs great at speed, but at 10 to 15 mph she surges a little. thanks griffy
Old Jan 5, 2011 | 04:43 PM
stro1965's Avatar
stro1965
Short answer...YES. I've run a T-Max on my '07 Ultra for 3 years now.
Old Jan 5, 2011 | 04:53 PM
seph10's Avatar
seph10
yes If your not going to do any super mods to the engine a fuel a pack works great,,,,I have one that I ran on a 07 road king for one season,,,works good and if it will work on your bike I'll sell it to you,,,,just let me know....
Old Jan 5, 2011 | 05:50 PM
griffy's Avatar
griffy
Thanks for the quick reply guys. SEPH10 I called V & H Fuel Pak and got a hold of a Derek in cust svc. He told me that the Fuel Pak would not help without a set of pipes and a intake such as the Screaming Eagle or the K and N. Thats why I was inquiring if another one might. I will now check on the T-Max. thanks again griffy
Old Jan 5, 2011 | 05:55 PM
10350's Avatar
10350
A PCV will be able to richen the mixture using the stock pipes and intake. Jamie at Fuelmoto can set one up to run on an '07.
Old Jan 5, 2011 | 05:59 PM
trekez2's Avatar
trekez2
Check out FuelMoto, a sponsor of HD Forum. Jamie can fix you up with pre-mapped systems and super support, no dyno runs necessary. A PCIII or V will make a huge difference in the way it runs and how cool it stays.
Old Jan 5, 2011 | 07:11 PM
txfxstrider's Avatar
txfxstrider
I did not think PCV was available for an '07. PCIII only.
Old Jan 5, 2011 | 07:17 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
my 07 ran way hot stumbled surged and pinged,started with ied"s kept the rest stock,ran better but would still ping when it got really hot,next stg1 from fuelmoto slip ons se backing plate and pcv,way happy camper.no more ping or surge or stumble, and so much more throttle response.that was with the canned map,no need for dyno time for me.later added a switch for 2 map setup better mpg on highway or rich map for heat control or backroading with the wife and gear onboard.
Old Jan 5, 2011 | 07:19 PM
bigdumbnoitall00
pcv on my 07 no problem,dyno jet didnt advertise it as fitting ,fuelmoto advertised it with a retrofit,dont know what the difference could be exept maybe the terminaters for the 02 sensors.
Old Jan 5, 2011 | 09:22 PM
MI_Jim's Avatar
MI_Jim
I'm running a PCV from Fuelmoto on my 07. Put it on in early '09 and added autotune & cams last year. For cooling & increased performance you can't beat their Power Package. IMHO it's the best bang for your buck out there.
