I don't like to trailer the bikes but 2 bikes 1 motorhome and trailer and only 2 drivers I don't have a choice.
Leave the motorhome at home.
Seriously, at the price of fuel for a motorhome, you could ride the bikes, rent rooms or campgrounds and come out ahead. Plus you would have the adventure of riding.
This is how I do it. I have the straps looped around the passenger footrest bracket and slightly forward pulling the bike forward into the wheel chock. Rock solid. I also let the air out of my shocks and place a block under the frame near the cross brace and tighten the straps until the bike rests on the block. This way the bike doesn't bounce on the rear shocks and snap the straps.
Since you tie down the front and are pulling it forward into the chock, all you really need is to keep the back from moving side to side.
A real easy way is to run a wrap a 4" lifting strap through the rim an tie down secure with a ratchet strap.
By locating the strap in the rim you are not restricting the suspension,and giving the stap a chance to break.
great job showing all straps pull the bike towards the front. if you have the rear straps towards the rear and the front loosens then the rear will be loose or will pull the bike backwards from the chock.
ORIGINAL: soos
