In-Dash iPod mount
Old Apr 3, 2011 | 09:40 AM
MTGlide's Avatar
MTGlide
Default In-Dash iPod mount
During the winter months, I got bored and started thinking about mounting options for my iPod Touch. I liked some of the custom consoles that hold your iPod but didn't want to spend $400 so I went ahead and built my own.
The materials used were a sheet of flat styrene, the plastic case that the iPod came in, some grey foam, and a cable to charge the iPod and connect it to the Aux port in the HK radio.
I started by tracing the shape of the opening in the chrome dash to get the basic shape of the console insert. Then, traced the opening for the iPod and cut the hole in the plastic sheet. During test fitting I found that some grinding would be necessary in order to allow the iPod to fit down into the console so I went ahead and removed some material with a grinder. Once I determined that everything fit properly, I glued the plastic case that my iPod Touch came in to the top piece and let it dry.
For the finishing touch, I went and found some carbon fiber film at a local auto parts store and used it to cover the new console insert. Double-sided tape is used to attach the new console insert to the tank console. The cable I'm using plugs into the iPod and runs to a USB charger and the AUX port.
I've used it a few times and so far, it seems to be working quite well. Here's what I ended up with.
Attached Thumbnails In-Dash iPod mount-sdc12104.jpg   In-Dash iPod mount-img_0072.jpg   In-Dash iPod mount-img_0078.jpg   In-Dash iPod mount-img_0083.jpg
Old Apr 3, 2011 | 09:45 AM
RollaMo's Avatar
RollaMo
That's pretty sharp! Good job.
Some of us don't have the talent to do things like that.
I purchased the "Riders Claw" for my iPod Touch, and am very happy with it.
But your setup looks great.
Old Apr 3, 2011 | 09:59 AM
Kesean's Avatar
Kesean
Looks good. Ironically I just ordered that $400 product.
Old Apr 3, 2011 | 11:23 AM
JoshuaCannon's Avatar
JoshuaCannon
Very impressive!!! Wanna make one for the Droid X ?
Old Apr 3, 2011 | 11:38 AM
DrPlastic's Avatar
DrPlastic
That is sweet!
Just one word of caution....I work with styrene all the time and you have to be very careful about what type of styrene you use. I hope you used a type that can handle heat. As most styrene will warp/melt is left out in the sun and heat for any length of time. I am planning on doing the same thing but using the original console I removed/replaced last year.
Old Apr 3, 2011 | 03:16 PM
07 SILVER BULLET's Avatar
07 SILVER BULLET
Thumbs up
great job!!
Old Apr 3, 2011 | 07:42 PM
MTGlide's Avatar
MTGlide
Originally Posted by DrPlastic
That is sweet!
I really hadn't thought about it melting in the sun. It's some stuff I had lying around from the hobby store - it's pretty stiff. I did heat it up in the oven at about 200 degrees to get it to curve a little when I was fabricating it. I'll keep an eye on it.
Old Apr 3, 2011 | 07:45 PM
MTGlide's Avatar
MTGlide
Sorry but making one is enough for me - it actually took me quite a few hours to get it right.
Not sure of the dimensions of the Droid X. If it's any bigger than the iPod touch it might not fit.
Old Apr 3, 2011 | 07:47 PM
MTGlide's Avatar
MTGlide
oops - double post
Old Apr 4, 2011 | 09:31 AM
jake0matic's Avatar
jake0matic
I bought another dash just to do this project myself, this looks great. Good job!!!
cuda67bnl
Jan 18, 2011 05:41 PM
pittz5
Jun 15, 2010 01:49 AM
leadman
Feb 14, 2010 10:58 AM
hdwd2000
Dec 20, 2007 08:42 PM
Deucegurl
Feb 26, 2007 11:36 AM
