I have to get a head set for Bike to Bike and also rider to passenger .
What is a decent set to get? There are MANY ? I don't want to spend a ton?
Thanks for your answer in Advance
Can those units be taken off and popped back onto the helmet at will. I use 1/2 helmets in the summer and 3/4 in the cooler months.
depends on your helmets...when i installed the scala's i had to use the "glue" attachment version, but the actual scala module can detach from the helmet attachment. so if you purchased multiple "attachments", the module could be moved from helmet to helmet.
as for the helmet attachments, there are two, one with the "glue" and another with a brace / screws that will allow it to be tightened down. again, comes down to your specific helmet.
