new member could use some advice. I bottomed out my rear tire and scraped the insulation off 4 wires under the fender. no speedo, tack, horn, brake light, and turn signals. no fuses are bad in the fuse block but the connector going to that harness is not hot except for runnin light which did not tear.
Remove the rear tire, get some heat shrink wire splicers and repair the wiring. These will give you a waterproof repair. Make sure the wiring is up and out of the way.
all wires seem to be still in tack and no fusses blown. Is there another fuse in the faring? Also the connector before the promblem is not hot except the blue wire forthe runnin light. thanks
