checking pinion runout
Old Oct 20, 2006 | 04:07 PM
dawg's Avatar
dawg
Default checking pinion runout
Dumb question....I must be overlooking the obvious. When you check pinion runout with a dial gauge, what exactly do you do? I know about putting the gauge onto the shaft, but then what? Do you turn the rear wheel and the shaft moves, or do you wiggle it in and out? [sm=dontgetit.gif]
Old Oct 20, 2006 | 04:42 PM
RKC2001's Avatar
RKC2001
Default RE: checking pinion runout
Checking the run out would involve turning it. You put the button directly on top of the shaft, make sure that the indicator stem is pushed in a little so that you can see if it goes negative, then zero the dial. Turn the wheel so the shaft rotates and see if the indicator on the dial moves more than specified tolerance.
I hope this helps.
Old Oct 20, 2006 | 06:27 PM
dawg's Avatar
dawg
Yup it does, thanks.
Old Oct 21, 2006 | 11:16 AM
1flhtk4me's Avatar
1flhtk4me
Also while the indicator is on the shaft,grab the shaft by hand and move it up and down to check the axial play.
SGT DNG
Sep 17, 2025 07:41 PM
sdecgreen
2014-2024 Touring Models
Mar 26, 2018 11:51 PM
rbt1548
Wheels/Tires
Feb 10, 2013 04:59 PM
gli.der
Aug 16, 2010 09:35 PM
jousley
Jul 23, 2009 07:51 PM
