Helmets
Old Oct 23, 2006 | 12:56 AM
planegene's Avatar
planegene
6th Gear
Default Helmets
I have just recently traded my custom 02 Night Train for a 07 Road glide (will never go back to a softail agin!) I am just having a little trouble finding the right helmet to ride with. With my softail I just wore a non DOT scull cap, but when I switched to a touring bike I figured I would go to a DOT aproved helmet. If I wear a helmet with a visor on it the helmet flutters. If I take the visor off the fluttering stops. When I put on a flip up clear sheild this also make the helmet flutter because of the built in visor on the shield. What kind of helmets are others wearing, full face, 3/4 helmets, 1/2 helmets, face shields or not?
Thanks
Gene
Old Oct 23, 2006 | 01:06 AM
Taterdog's Avatar
Taterdog
Default RE: Helmets
I wear a 3/4 helmet with visor when I ride. Never had a fluttering problem. Sure you're tucking your ears in before you startup?
Old Oct 23, 2006 | 01:10 AM
SpikeCT's Avatar
SpikeCT
Default RE: Helmets
Harleys 1/2 helmet without visor. had to order it. its in the book.
Old Oct 23, 2006 | 01:17 AM
Mick's Avatar
Mick
Default RE: Helmets
Hey Plane , don't know much about the airflow on a RoadGlide , but maybe the Fork Air Baffle would help.
Part # 58520-79TC stops alot of up-flow from the fuel tank area on my EG Standard.
The listing shows it should fit yours also.
Just get a helmet that "fits you" the best and I'm sure the guys around hear can help you more.
I ended up getting a HJC half helmet , only because the Harley helmets would not fit (my head) very well.
I do like the visor especially going into the sun near the end of the day on a ride.
good riding.
Mick
Old Oct 23, 2006 | 04:58 PM
rdam's Avatar
rdam
Default RE: Helmets
ORIGINAL: Mick
Does the air baffle reduce, or re-direct airflow away from the engine? Has anyone noticed an increase/decrease in oil temperature after installing the baffle?
Old Oct 23, 2006 | 06:45 PM
Mick's Avatar
Mick
Default RE: Helmets
Hey RD , supposedly the baffle came as standard equipment on all 2000 and earlier touring models.
It fits from 1980 and up, although some may have been black not chrome.
Now it's an accesory (imagine that).
I don't have any real evidence that the engine runs warmer,although it directs the air towards the front cylinder slightly lower and more forcefully than without it.
It works pretty well for rider comfort though.
Mick
Old Oct 23, 2006 | 08:54 PM
Streetrunner's Avatar
Streetrunner
Default RE: Helmets
3/4 with face shield for winter, 1/2 HD helmet with ear flaps for spring and fall and my favorite 1/2 carbonfiber helmet (DOT) for summer. Check this link out.
http://carbonfiberhelmets.com
Old Oct 23, 2006 | 09:31 PM
ironoxide's Avatar
ironoxide
Default RE: Helmets
Full face all the time...I like my looks.
Old Oct 23, 2006 | 09:54 PM
allikanbe's Avatar
allikanbe
Default RE: Helmets
Arai full-face all the time. Warm in the winter. Warm in the summer too, but I can deal with that. Crack open the fac shield if you want more breeze.
Old Oct 23, 2006 | 11:03 PM
travlr's Avatar
travlr
2nd Gear
Default RE: Helmets
I noticed the same problem.
But it's not an issue with my Nolan Full Face.
T
