SE Compensator I recommend
Old Jun 15, 2011 | 06:51 AM
Inspector 12's Avatar
Inspector 12
Originally Posted by hydrolock43
If i was you i would'nt leave ATF in with that new SE compensator. Do a search on this forum or Harley tech talk, such as compensator woes. The SE compensator will start fretting in its bore very quick with atf and start tearing itself apart much quicker than with a heavier oil such as Formula plus. There also is a modification to the compensator gear to help getting lube into the bore. I have a Rivera primo pro with a lockup head in my primary and it works fine with the 40w Formula plus. My brand new SE compensator looked realy bad at 1000 miles with Redline MTL in the primary which is just like atf. Take a look at it after 1000 miles if you leave the atf in there you will see a rusty red goop coming out of the SE compensator bore which is fretting totaly starts chewing the SE compensator bore and spokes apart very quickly. I was glad to see a brand new SE compensator in the crate with the 120R i installed to replace the one that i put on the 96'' 1000 miles earlier. Clutch likes atf but compensator suffers severly, it needs a much different lubricant to survive.
Agree on the need for a good lube in the primary. After hearing all the stories about "fretting" on the SE compensator the tech that did my SE 120R install started doing some digging. Seems the "recommended" lube (according to his source at MOCO) for the SE comp is HD Formula plus. So far it is working out just fine on my 06 Street Bob with the SE 120R and no signs of fretting on the comp.
Old Jun 15, 2011 | 06:55 AM
lionsm13's Avatar
lionsm13
Many grind grooves into the spokes of the compensator which is supposed to aid in the lubrication process..
Old Jun 15, 2011 | 05:52 PM
Ultra61's Avatar
Ultra61
Originally Posted by 07RoadHawg
Is there something special about a Rivera clutch that makes it a PIA to remove? No sarcasm, I'm just curious.
It's just alittle more involved than one bolt to remove the basket thats all and I love the way I have it adjusted right now.
Old Jun 15, 2011 | 05:59 PM
JayStronghawk's Avatar
JayStronghawk
Went to a SE Comp at 30,000 .. Told my situation of the clanks, bangs, grinds whatever wish to call them to the Dealer.. They replaced the stock with a SE free under warranty, when told them if they all have them in 2011, should be considered a stock replacement now .. Love the difference now no more noise ..
NMNSG08's Avatar
NMNSG08
I just replaced my compensator on my 08 sg sunday and i will agree, wow what a difference. i should have done it sooner.
Old Jun 15, 2011 | 06:10 PM
Ultra61's Avatar
Ultra61
Originally Posted by IndyClassic
There are a few write-ups in here with great pic's on the swap-out. I stole this one off one of them showing the primary edge shaved so the original comp clears.
Thanks for pulling the photo. I never did find photos in my search.
In case some are wondering ~ I used a non-ferrous die-grinder bit with a die grinder, air compressor needed.
My work looked better...........JK
Old Jun 15, 2011 | 06:12 PM
Ultra61's Avatar
Ultra61
Did that... Sarge sent me the info on that. Thanks
Old Jul 27, 2011 | 10:38 PM
Dick1964's Avatar
Dick1964
I used ATF because that is what the clutch manu recommended, I was not educated and took the suggestion. Aprox 1300 miles later I'm replacing the SE comp. I'm glad I saw threads like these before I made the same mistake again.
LoveHate
Nov 18, 2014 11:36 AM
harley_jeff
Exhaust System Topics
Dec 29, 2011 10:21 PM
Feedsack
Apr 4, 2011 08:08 PM
SCJE8
Feb 18, 2011 02:44 PM
G wizz
Nov 27, 2008 09:27 PM
