SE Compensator? Replace primary adjuster?
Old Dec 28, 2011 | 07:19 PM
harley_jeff's Avatar
harley_jeff
Default SE Compensator? Replace primary adjuster?
OK, I am dialing in all the parts I need for the 96" to 103" conversion. Looks like I am going to have to remove the primary cover to deal with the clutch (either conversion or heavy duty spring), and I also noticed today that I have an oil leak where the shifter shaft comes through the cover.
So, since I have to remove the cover, I was wondering what else to do while I am in there.
Is the SE compensator worth $200 (discounted)? Should I replace the primary chain tensioner (bike has over 21K miles on it)? Should I replace the transmission pulley with a 32T ---> 30T? What else is inside of that area?
Old Dec 28, 2011 | 09:17 PM
DRAGO'S BIKE WORKS's Avatar
DRAGO'S BIKE WORKS
Former Sponsor
Give us a call if you want to pick someones brain. We would be more than happy to walk you through it.
Thanks
FDrago.
Old Dec 28, 2011 | 09:20 PM
soft 02's Avatar
soft 02
Depends. Does it have the dreded start up bang? My auto primary has about a 1/16 wear at 99,000 miles. And most say that the added SE spring is good to 120hp+-. I consider the SE comp the best no-bang for the buck thing I have done to mine!
Old Dec 29, 2011 | 12:44 AM
djl's Avatar
djl
No need for the SE compensator unless you just want to spend the money. OEM primary chain tensioner is fine at 21K miles; they will last much longer. There have been problems with the SE compensator. 30T trans pulley is a good idea as is the SE spring.
Old Dec 29, 2011 | 10:34 AM
harley_jeff
Thanks DJL. As always, you rock. I am about half-way through Donny Petersen's book and I just finished the section on gearing. Interestingly, H-D used a 66 nub rear pulley from '07 - '08 (my bike is an '07). This results in a final drive ratio of 2.79:1. In 2008, they went back to a 68 nub rear pulley (which the '06 Dyna had). This gives a final drive ratio of 2.88:1.
I think most people agree the gearing is too tall, hence the desire for the 30T transmission pulley, but I wonder if just the 66 nub rear pulley would get the job done. From above, that is 2.88:1. If I stick with the stock '07 68 nub pulley and swap out the transmission pulley for the 30T, that would give me 46/34 * 66/30 = 2.98:1 final drive ratio. Is that not tall enough?
Old Dec 29, 2011 | 11:03 AM
djl's Avatar
djl
We need to agree on nomenclature. In gear head lingo, the 2.79 final drive is "taller" than the 2.98 final drive. It's bass ackwards, the higher the ratio; the "lower" the gearing and the lower the ratio, the "taller", or higher, the gearing.
So, the 2.98 final drive is lower than the 2.79 or 2.88 which means the torque mulitplier of the final drive is increased; your highway rpms at cruise will increase a bit and you will be able to engage 6th gear earlier. By comparison, the earlier 5 speeds had a final gear ratio of 3.15; cruise rpms at 70mph are about 3000rpms.
Old Dec 29, 2011 | 11:18 AM
harley_jeff
Right, the higher the number the more the engine turns relative to the rear wheel.
The lower the number the "taller" the gearing.
So, my current final drive = 2.79, and 6th gear is kind of marginal.
66 --> 68 nub rear pulley = 2.88, and 6th should be useful earlier as you said.
32T --> 30T = 2.98 (with 66 rear pulley), and 6th should be useful even earlier.
So, what do think is a good final drive ratio number?
Back to the original question about what to do once I remove the primary cover, I think we agreed leave the compensator alone, fix the oil leak at the shifter shaft, leave the tensioner alone, deal with the clutch (either VPC or heavier spring).
Old Dec 29, 2011 | 11:41 AM
djl's Avatar
djl
OK, we are on the same page, just wanted to be sure. Your riding style will determine what final drive ratio works best. Both my bikes are older and five speeds; I have no issues with the 3.15 final drive so, if it were me, I would be replacing the trans pulley with a 30T for the 2.98 final drive.
Yeah, leave the compensator alone, fix the oil leak at the shifter shaft, leave the tensioner alone, deal with the clutch. If you have the coin, the VPC is a better option; the SE spring did not hold my 95" build, started slipping after about 2500 miles and the clutch pull was stiffer. The VPC will hold and the clutch pull is reduced to two fingers. I dropped the Deuce going into a corner, lowside, and broke most of the clutch lever off. It would have been real tough getting home with a 1" clutch lever.
Old Dec 29, 2011 | 11:46 AM
Barney Biker's Avatar
Barney Biker
If you go to the 30 tooth pulley you are removing the 6th gear.
It will be like being in 5th when you are actually in 6th.
The SE comp makes a world of difference in the noises when starting the engine.
I am using the rear sportster 68 tooth pulley and it helps a lot with the high gearing.
Barney
Old Dec 29, 2011 | 06:36 PM
harley_jeff
Barney
Well, they also make a 31T xmission pulley; however, if you do the math you wind up with the same final drive ratio as going from 66--->68 teeth (nubs) on the rear wheel sprocket, which is 2.88:1. This is the same ration as the '06 Dynas, and according to Donny Petersen, what H-D went to on at least the baggers starting in 2009. Next time I am at H-D I'll look at a parts book for the 2009 - 2012 Dynas, as I only own the book for my bike ('07).
