thinking bad sensor..help!!
Old Jul 10, 2011 | 01:55 PM
GeorgeW1's Avatar
GeorgeW1
Stage II
Default thinking bad sensor..help!!
2000 ultraclassic, bike starts and runs fine,, when accelerate motor stops as if it ran out of gas..checked fuel filters all seem clean,at times to get it to start have to remove fuel line from tank to release pressure no codes are displayed so cant find problem help...
Old Jul 10, 2011 | 02:00 PM
soft 02's Avatar
soft 02
EFI? Carb? Maby you have a hole in your fuel line in the tank. Only gives enough pressure at idle to run and when you ask for more she dies. Welcome to the forum!
Old Jul 10, 2011 | 02:30 PM
GeorgeW1's Avatar
GeorgeW1
Stage II
efi not delphi has return port in tank,, has pressure on line when i pull line from tank,, bike runs fine only stops when u accelarate...
Old Jul 10, 2011 | 03:28 PM
twistedcherokee's Avatar
twistedcherokee
A weak fuel pump may have enough to idle but not be able to support anything off idle. Get a fuel pressure gauge & check pressure & flow. Too bad your not in Colorado, I would be able to help more.
Toby
Old Jul 10, 2011 | 03:39 PM
dawg's Avatar
dawg
Check the crank sensor.
Old Jul 11, 2011 | 06:55 AM
imrotton2's Avatar
imrotton2
fuel filter in the tank could be clogged...does it seem like the pump runs a little longer than usual???
wedgemoose
Jul 13, 2020 12:51 PM
rage4order
Jul 8, 2015 10:22 PM
fullswedge
Nov 27, 2013 06:48 PM
clapper
Jul 15, 2013 12:10 PM
badbags
Mar 23, 2011 07:49 PM
