Audio question
Old Jul 14, 2011 | 08:21 PM
jrcisu79's Avatar
jrcisu79
Default Audio question
From what I have gathered the head unit in my 2011 RG puts out a 2 ohm signal. I have been looking at buying the Rockford Fosgate PBR300X4 amp and the Rockford Fosgate P1653 6.5" speakers and driving them with the stock head unit. My question is the speakers and amp are rated at 4 ohms, what issues if any is that going cause me.
Old Jul 14, 2011 | 09:18 PM
AbnMP13's Avatar
AbnMP13
Subscribed.
Old Jul 14, 2011 | 10:10 PM
vickers1's Avatar
vickers1
None at all.
Old Jul 14, 2011 | 10:11 PM
Nickpisp's Avatar
Nickpisp
They will get half the power of the 2 ohm speakers.
Old Jul 14, 2011 | 10:23 PM
dhincc's Avatar
dhincc
None. The speakers will get their signal lfrom the 4 ohm rated amp, and they're 4 ohm rated speakers. It doesn't matter what the head unit is rated at.
Ride safe!
Old Jul 15, 2011 | 08:52 AM
stuart1270's Avatar
stuart1270
Ride safe!
Listen to this guy he knows what he is talking abuot
Old Jul 15, 2011 | 09:07 AM
Copyless's Avatar
Copyless
It's not going to cause any issues, it will work just the way it is designed to.
Old Jul 15, 2011 | 09:10 AM
Harleypingman's Avatar
Harleypingman
The HK head unit won't "drive" anything; it simply supplies the audio signals to the amp (which has an output rating of 4 ohm impedance as you say, but no input impedance spec). The fact that the HK is a 2 ohm impedance output won't have any effect on what you're planning. I have the same HK and amp set-up (w/ different speakers) and am very pleased with the power and sound albeit in a 4-channel set-up.
Carl
Old Jul 15, 2011 | 10:02 AM
Shakeydeal's Avatar
Shakeydeal
Wrong!
As already stated, the HK is only giving you a signal, as shtty as that may be using adaptors. But you are bypassing the amplifier section and only using the HK as a preamp.
At some point you would be well advised to buy an aftermarket deck with true preamp outputs. This will improve your sound for sure.
Shakey
Old Jul 15, 2011 | 10:06 AM
alkrisma's Avatar
alkrisma
good to know
