Security PIN
Old Jul 16, 2011 | 08:58 PM
conmore's Avatar
conmore
Default Security PIN
Hi there
Quick question: I've read a few posts about setting a new PIN and the sequence required to do that or in fact manually disabling the security.
If all I want to do is view the current PIN that is set, using the sequence, once the PIN is displayed and I want to keep that PIN do I just turn the ignition to OFF and it's retained?
Cheers
Old Jul 16, 2011 | 09:09 PM
Copyless's Avatar
Copyless
Yes...
Old Jul 16, 2011 | 09:16 PM
K Melancon's Avatar
K Melancon
To view or change,
Ignition, off, Ignition, off, Ignition, Left blinker switch 3 times fast, then right blinker fast once,
The odometer will dispaly the currect PIN # if you want to change press left blink number of times and set it with rt blinker. When finish turn ignition off and will store #
Guess I didn't read through your entire post, YES. I was just glad I learned this.
Old Jul 18, 2011 | 02:00 AM
conmore's Avatar
conmore
Hi there
Thanks for the replies. Tried it today and yes you have to be fairly "speedy gonzales" to get the sequence happening correctly, but I managed to get it to display the current PIN which is correctly recorded in the manual, so I'm happy.
Also practised disabling the alarm system using the PIN just in case
Cheers
Old Nov 3, 2011 | 03:20 PM
zoozoo's Avatar
zoozoo
Another question about changing the security PIN number. When you change your PIN number and you have 2 fobs should you have both of them with you when you change the number?
Old Nov 3, 2011 | 03:22 PM
slothy's Avatar
slothy
as far as i know the pin number has nothing to fob.. its stored on bike (not sure radio or ecm?) in case you lose fob or fob battery dies.
Old Nov 3, 2011 | 03:26 PM
sanlyn's Avatar
sanlyn
I believe the PIN is independent of the fob.
Old Nov 3, 2011 | 03:34 PM
zoozoo's Avatar
zoozoo
OK ,thanks. I bought a 2010 Ultra this past September and just check my PIN and its 11111. Fist time I looked at it. I think I had better change it.
Old Nov 3, 2011 | 03:54 PM
skratch's Avatar
skratch
well, yeah, now that you told us what it is
Old Nov 3, 2011 | 03:59 PM
caspr2's Avatar
caspr2
Yes you better, that is the pin most dealers use. Kinda like leaving your keys in the bike saying come and get me..
