Simple wiring question
Old Jul 22, 2011 | 12:04 PM
Moosestache's Avatar
Moosestache
Default Simple wiring question
I have an lcd license plate bracket that has two wires and is supposed to wire into the tail lamp on a 2010 road king. There are three wires going to the tail lamp bulb, blue, black, and red. I am supposed to wire one line to the power and one to the ground. I have gotten conflicting info on which wire is which. The last I heard was the blue is the power I want, and the black is ground, but before I messed things up too bad I wanted to check. If the black isn't ground, what is the easiest way to ground the wire, I didn't see any ground screws located in the tail light.
Thanks for the help!!
Old Jul 22, 2011 | 12:40 PM
Riff Raph's Avatar
Riff Raph
When in doubt test the wires with a test light...that said...I would assume that black is ground and red is power and blue is brake. What power you want depends on what you want the license plate bracket to do. If blue is brake then the power will be applied to the bracket only when the brakes are applied. I don't have my service manual for that model handy but I checked my softail manual and saw that the red is actually red/yellow which is typically ignition power (power on when the ignition is turned on) and there is supposedly another wire and a blue wire. Again depending on what you want the bracket light (I assume) to do then that's where you hook up. Test the leads first using either a test light or a voltage meter to be sure before you start splicing.
Old Jul 22, 2011 | 01:59 PM
jerseyjeff62's Avatar
jerseyjeff62
Blue is tail
red is stop
black is ground
Old Jul 22, 2011 | 02:02 PM
Moosestache
Thank you very much for the help.
krilla_kurt
Apr 22, 2014 12:49 AM
emperor wurm
May 21, 2012 03:58 PM
groaning
Sep 3, 2011 05:05 PM
Ric27
Jul 26, 2010 06:26 PM
mkelley
Oct 9, 2006 04:55 AM
