Is this normal
under reving the motor is often referred to as lugging.
It will damage the lower end bearings due to stresses, and does not provide proper oil pressure or volume through the motor, the charging system is also affected.
--- that reason that operation is not smooth is because the drivetrain is struggling.
current lightened flywheels ( crank) have little forward energy stored, it is different if the motor is turning a large rotational mass ( which would be the cranks used on the antiques)
For low speed operation ( parking lot cruising, parade, u turns manouvers etc.) check out the youtube tutorials by jerry palladino.
the technique involves using the rear brake lightly to hold the bike upright, while slipping the clutch in a controlled manner.
Mike
on that note what is the red line for the 88's ? the bike never came with an owners manual so I have ordered one but still a week or so away so I have been reading on here about oil and such trying to learn the basics fast. the main place I notice the surging is school zones where I have to do 20MPH and I am in second gear.. guess I'll stay in first now, I guess the whole thing is I didn't think you would have to go 1000rpm over idle befor it runs smooth, seams like a big gap.
Steve
One you get over 2000 notice how it smoothes out.
Thing to learn is do not lug the motor.
cruise at.
on that note what is the red line for the 88's ? the bike never came with an owners manual so I have ordered one but still a week or so away so I have been reading on here about oil and such trying to learn the basics fast. Steve
The owners manual will answer most of your questions. Most responses you've gotten have recommended 2000 rpm as an absolute minimum running speed. I think you'll find that you can go below that in the lower 2, maybe 3 gears but it really is a practical minimum in the upper gears. One way or the other, then engine itself will teach you that!
FWIW, the owners manual on my 09 Ultra has the usual recommendations for when to shift gears for best economy. As it turns out, upshifting at the recommended speeds always puts my engine right at 2000 to 2100 rpm after the shift.
Ride Safe,
Steve R.
