Finding a rattling problem
Old Jan 10, 2012 | 05:54 PM
giobott's Avatar
giobott
Default finding a rattling
check the allen head bolts holding the ehaust crossover mount to the engine. If not tight they squeak which sounds like a high pictch rattle
Old Jan 10, 2012 | 06:44 PM
TWIN CAM 96's Avatar
TWIN CAM 96
How about the solenoid cover or loose rear brake line/ rear brake lever/ floor board mount or bolts ?
Old Jan 10, 2012 | 06:47 PM
AlanStansbery's Avatar
AlanStansbery
No specific advice, just a general observation. Sounds heard through a helmet are much different when heard with the helmet off. I had an issue in which the starter was kicking in randomly. I could not identify the sound with my helmet on (I wear a full-face). The first time it happened without the helmet on my head, I knew immediately what it was... With the helmet on, it sounded like I was dragging a stick along the ground, or like it was a weird rattle...
Alan
Old Jan 11, 2012 | 09:18 AM
carlero's Avatar
carlero
Stage I
Default Road King Rattle
I've noticed on my 05 RK that the front fender running light lens cover rattles along with the head light nache top center strip trim piece. Tape them down and take a ride.
Old Jan 11, 2012 | 11:14 AM
sgdiesel's Avatar
sgdiesel
I normally work through a structured process of elimination, for example
Is the rattle related to road speed or engine rpm? If you get to a speed where it is rattling pull the clutch in and listen.
If engine related, is it at same rpm in all gears or across all revs in a certain gear etc? This can tell you whether it is engine or transmission
Is it a resonance sound? Loose bolts and fixtures tend to vibrate in quite a specific range, not higher or lower rpm
Is it metal on metal or rubber?
Old Jan 11, 2012 | 11:17 AM
sgdiesel's Avatar
sgdiesel
Another tip for finding rattles, although not applicable in this case as you cannot get it while stationary, but using a long screwdriver, place the tip on the area you suspect and push your ear against the handle, you will be amazed how accurately you can pinpoint noise this way
Old Jan 11, 2012 | 11:25 AM
Pumba11's Avatar
Pumba11
Another similar tip that I use is, if you can get it rattling on the stand or whatever, I use a paper towel cardboard tube to listen through. Move it around and you will easily pick up where the rattle is coming from.
Old Jan 11, 2012 | 11:46 AM
clap's Avatar
clap
Did you check the rubber blocks that hold your mufflers up at the top rear of the mufflers. They have been the rattle of many a bikes. I have replaced mine a couple times. Only a couple bucks each.
Old Jan 11, 2012 | 12:29 PM
EasternSP's Avatar
EasternSP
Crash bar lower mounts.
Old Jan 11, 2012 | 12:39 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
you know that the original post was back in august right?
