1 Week after 577 WILD ONES installed problems have developed with my cables.
Old 08-23-2011, 08:20 PM
C908's Avatar
C908
C908 is offline
Default 1 Week after 577 WILD ONES installed problems have developed with my cables.
Well today when I parked my bike and was locking the fork I noticed the Clutch cable was pinched. When I got it free I noticed the outer coating was cut.These are my brand new Magnum black pearl cables.It seems the fellow I had install them got the clutch cable tangled with what I believe is the wiring for my spot lights.If I turn my bars to the right it puts to much pressure on my spot light wiring because the wires are in a bind with each other.My question is do you think I can disconnect the clutch cable from the tranny and then pull it up and get free from the spot light wiring and then reconnect it. I'm thinking I might need to zip tie the clutch cable at some point so it doesn't work it's way back to the pinch point.I forgot to mention I have a 2010 Ultra Classic and the clutch cable is a +6 which is what Wild Ones recommended with their 12 1/2 inch Apes.Another question is it normal to feel movement in the bars if you push on them gently.I'm not talking about slipping in the clamp area but rather seeing the upper part of the bars move,almost what I would consider flexing. Thanks for your comments.
Old 08-23-2011, 08:58 PM
07DDreamHD's Avatar
07DDreamHD
07DDreamHD is offline
Yes, you will notice some flexing in the bars. The clutch cable should be routed from the tranny, along the lower frame, then between the down tubes at the bottom, then between the engine guard and the down tube on the left side (hope this is clear enough to understand), then into the fairing. If it is not routed this way, you will pinch the clutch cable between the downtube and the lower triple tree.
Old 08-23-2011, 09:13 PM
pettifogger1's Avatar
pettifogger1
pettifogger1 is offline
I would disconnect the clutch cable from the handlebar. A lot easier to remove a clip and pin from the lever than to remove the cable from the tranny. The bushings the handlebar clamp is bolted to are rubber. If you want to reduce the flex you need to install poly bushings.
Old 08-23-2011, 10:13 PM
C908's Avatar
C908
C908 is offline
Thanks for the response from both of you. I thought about disconnecting from the handlebar but thought in order to go that route I would also have to take the outer fairing off is that not correct? It looks to me like he ran the cable over the lower triple tree instead of under it, does that make sense? You also mentioned Poly bushings and yes I did install them.
Old 08-24-2011, 11:10 AM
Vile Lou's Avatar
Vile Lou
Vile Lou is offline
I had 16" wild ones on my fat boy. They flexed when I needed new bushings in the risers.
Old 08-24-2011, 01:00 PM
bks's Avatar
bks
bks is offline
I would rather pull the outer fairing than the transmission cover.
PacBlue_07
06-09-2019 11:25 AM
ocezam
10-26-2013 08:46 AM
cmosentine
03-24-2013 09:43 AM
DynaJ
05-09-2012 06:41 PM
Swamphunter
11-09-2007 12:37 PM
Quick Reply: 1 Week after 577 WILD ONES installed problems have developed with my cables.
