Installing fat cat
Old Aug 30, 2011 | 12:00 PM
elauee1's Avatar
elauee1
Default Installing fat cat
I am going to install a d&d fat cat on my 2010 fltrx. Any instal tips from any one who has done this on there own. Thanks
Old Aug 30, 2011 | 12:02 PM
'05Train's Avatar
'05Train
The directions are pretty straightforward. Just remember to wipe the whole thing down with Windex before you start the bike.
Old Aug 30, 2011 | 02:50 PM
jeffreyjames's Avatar
jeffreyjames
Why the windex?
Old Aug 30, 2011 | 02:56 PM
masterblaster's Avatar
masterblaster
And wax it with a good quality wax, polish and wax after the firs few heat cycles (re torque after first few heat cycles to make sure everything is tight), read the instructions that came with it on care of the chrome. Windex gts rid of any oils and prints and keeps them from baking in on first heat cycles, the wax puts a good base on the pipe. Best pipe, best chrome anywhere.
Old Aug 30, 2011 | 04:15 PM
elauee1's Avatar
elauee1
Anybody know the tourqe speck for the head flanges. 2010 fltrx
Old Aug 30, 2011 | 09:58 PM
jeffreyjames
I imagine this doesn't apply to the black pipe.. right?
Old Aug 31, 2011 | 07:00 AM
crewchief25's Avatar
crewchief25
I just installed a fatcat yesterday and needed to double up on the SE exhaust gaskets cause the from header would touch the cam cover cone, per Leanard at D&D.
Old Aug 31, 2011 | 07:12 AM
Iceman24's Avatar
Iceman24
Windex the pipes before starting to get all the prints/grease off...otherwise you'll have marks burned into pipe(s). Also, get some HT silicone (liquid copper) for the header/pipe seal. Good luck, enjoy - they're great pipes.
Old Aug 31, 2011 | 09:27 PM
Phat09flhx's Avatar
Phat09flhx
I great tuner told me when I was going to a Fatkat from a Caliber to leave the mounting bolt on the trans loose and snug the exhast nuts firm, start the bike and let run till hot then let cool and you will get several more turns on the nuts. Warm the bike again and repeat then tighten up the mounts and you'll never have a problem with leaking gaskets.
Old Sep 2, 2011 | 07:12 AM
elauee1's Avatar
elauee1
D&d might have changed the gaskets that they supply. I bought 2 sets of the se gaskets, but the d&d ones r twice as thick as the se.
