Remove brake calipers to remove front wheel?
Old 08-30-2011, 07:30 PM
V2Evo96's Avatar
V2Evo96
V2Evo96 is offline
Question Remove brake calipers to remove front wheel?
I want to drop the front wheel off in order to remove the bumper bar 'ornament' from the front fender on the 09 BargeGlide.
The SM states remove the calipers prior to removal of the axle/wheel. Is it really necessary?
I would have thought the front wheel would drop out of the caliper pads and just slot between the pads on re-installation.
Out of more than a decade of riding HD's I've never had to remove a wheel, hence not sure.
Can anyone shed some light on this query? Big thanks in advance.
Old 08-30-2011, 07:34 PM
Notgrownup's Avatar
Notgrownup
Notgrownup is online now
Received 6,552 Likes on 3,356 Posts
Gotta take at least one off....I usually take both off because it gives me an opportunity to inspest them...
Old 08-30-2011, 07:39 PM
Fast Aire's Avatar
Fast Aire
Fast Aire is offline
Former Sponsor
The tire sticks out past the rim & caliper so one caliper needs to come off. But its only two bolts per caliper so its easy take them off, tie them back to the crash bar & do your work. Its alot easier that way
Old 08-30-2011, 08:18 PM
V2Evo96's Avatar
V2Evo96
V2Evo96 is offline
Talking
Cheers guys-- much appreciated! I'll go ahead and pull both calipers, with due caution regarding the ABS.
Old 08-30-2011, 09:01 PM
mfortkamp's Avatar
mfortkamp
mfortkamp is offline
I was able to take my bumper bar off without dropping the wheel. I think that I used a ratchet wrench and turned it backwards.
Old 08-30-2011, 09:42 PM
V2Evo96's Avatar
V2Evo96
V2Evo96 is offline
I could do that--there's enough room-- but I couldn't get into the area where the locking tab for the fender fasteners is located, to get to the rear bumper mount.
I tried to get to them via a long drift punch between the wheel spokes, but couldn't bend the tabs enough to get a spanner over the fasteners (in order to remove the rear bumper mount).
Did yours have locking tabs and if so how did you bend the tabs back?
Old 08-30-2011, 10:10 PM
SIU 96's Avatar
SIU 96
SIU 96 is offline
With the calipers off you can check the wheel bearings before and after you take the wheel off.
wscott
08-24-2016 08:42 AM
Turtles70
05-06-2012 08:30 PM
ctmedic
04-28-2008 05:49 PM
jbt
11-06-2006 06:07 PM
100thRK
05-11-2006 12:16 PM
Quick Reply: Remove brake calipers to remove front wheel?
