Installing Stereo Help
Hey guys, so I just purchased all new audio gear. I have a radio, 4channel amp, and speakers. Is there a good guide out there that is helpful when wiring this all up? I'm a little lost right now, and any guidance would be great.
I am confused about a couple of things you stated. First, I believe (not sure) that JR music has the nomenclature wrong but the description correct. So I am guessing this is where you ordered your kit from? The reason I say this is, the number you give, MC-HON-AK4 is for a Honda motorcycle not a Harley, the number for the Harley is MC-HD-AK4, but again a couple of places have the ordering number wrong but send the correct item.
Second, I wonder why you would purchase that kit, if it is indeed the one for the Harley, because it sounds as if you are using a different radio and the most expensive part of the kit is the harness.
Maybe you actually are using the MC-HON-AK4 because it matches up to the aftermarket radio? Maybe you can clear this up for me, other than that, it should be pretty straight forward.
The Bazooka kits are plug and play, so it should be easy to install following the directions that come with the system as Copyless explained. The HD kits are not shown available specifically for the Road Glide, so that may be why you had to purchase the MC-HON-AK4 kit.
