LED Help 98 Road King
Hello all, my neighbor has a 98 Road King, he put on an LED tail light and purchased the disc style LED blinkers (plug in the original light socket) for the back w/connector to make them running / break lights. The tail light works great, but the blinkers come on as running / break lights but won't flash as blinkers. Any help with this issue would be greatly appreciated.
Thank you,
Dan
Thank you,
Dan
the turn signal system needs to "see" a certain resistance- and was designed for conventional light bulbs.
a switch to LEDS requires a "load equaliser".
check custom dynamics, or badlands.
year and model have to be correct
mike
mike
Thank you,
Dan
Thank you,
Dan
#2 Is bike still factory? or did someone complete a common alteration/change of installing front turn signal housing in the rear so they could use dual filament bulbs and then have either running OR brake lights and blinkers.
*what does inside of socket look like?
mccuned
Electrical/Lighting/Alarm
Sep 26, 2016 08:40 AM
