Stripped allen head Help.....
Old Dec 29, 2011 | 03:49 PM
Rock Chalk's Avatar
Rock Chalk
I've got this same kind of issue right now. Just put on new bars and when I went to adjust, I stripped out one of the allen heads on the bar clamp. There are several ideas on this thread, but which is going to be best for this situation?
As always, thanks guys.
Old Dec 29, 2011 | 04:04 PM
JJHOG's Avatar
JJHOG
Lesson learned here fellas with those pesky lousy stinking allen head lower fork leg bolts?
Make sure you start out using an impact wrench with a brand new allen head socket.
Replace the allen head bolts with torx head bolts when done, just in case you have to get into those pesky fork lowers again.
Old Dec 29, 2011 | 06:45 PM
sgdiesel's Avatar
sgdiesel
I hate easy outs, they cause more hassle than they are worth.
I am pleased you managed to get the broken one out, often you won't be that lucky
Northside, I am Interested in the ball bearing solution, haven't come across that before. You don't mention what size ball relative to the head, could you supply more info please
Old Dec 29, 2011 | 10:11 PM
Northside's Avatar
Northside
In the course of my occupation I ran into a ton of 1/4-20 SHCS that had the heads turned out. For those I use a 3/8 to 1/2" ball bearing. Just so the ball is larger than the socket and still centers itself into the socket when you lay it on there. Give it a good whack or two. Watch your fingers. The impact of hitting it combined with the swaging the socket does the trick. Whack it until you have to tap the allen wrench into the socket. I made a set of T handles from 1/2" round stock. Used 1/4" for cross piece and they are great for tapping into a swaged allen socket. Seriously I have removed at least a thousand turned out allens this way over the years. I really can't remember a time that it failed.
ralfie
Apr 5, 2014 09:33 PM
osirisdean
May 15, 2011 11:06 AM
codycuster
May 8, 2010 10:29 PM
sidewayzls1
Jul 15, 2009 07:22 AM
Streets of Fire
Oct 1, 2008 08:19 PM
