Installing PC III
Old Nov 25, 2006 | 12:26 PM
HawgMan_renamed's Avatar
HawgMan_renamed
Default Installing PC III
Just exactly what is involved
Old Nov 25, 2006 | 12:49 PM
wishbonecg's Avatar
wishbonecg
Default RE: Installing PC III
Just follow the instructions. Remove right side cover, loosen ecm enough to get a zip tie around it, fasten PCIII to ecm using zip tie, unplug ecm and plug in PCIII. That's it. Of course you need to have the correct map on the PCIII as well. Pretty easy process.
Old Nov 25, 2006 | 12:55 PM
lp's Avatar
lp
I'll give you the physical aspects of it. Someone else can comment on the software setup etc etc.
Take off the right saddlebag.
Take off the right access panel (thing below your leg) I forget the real name...
I would take off the seat and disconnect the battery.
Unplug the big harness from the EFI module and plug into the Power Commander.
The Power Commander has it's own harness, plug it into the EFI.
Route cables and stuff as it's kinda cramped in there.
Use your choice of mounting method to attach the Power Commander to the top of the EFI module. Most people use zip ties.
Thats it. Easy.
Now you just follow the rest of the directions that come with the unit that show you how to connect your laptop etc to the thing.
Good Luck.
lp
Old Nov 25, 2006 | 02:04 PM
notarheli's Avatar
notarheli
Need I say, "it's so easy a caveman could do it."
Old Nov 25, 2006 | 02:53 PM
HawgMan_renamed
HAHA well in that case, I ought to be able to take care of it. Thanks for the info.
Old Nov 25, 2006 | 03:04 PM
sportyrider1's Avatar
sportyrider1
hardest part on my RK was getting the velcro in the right place to keep the plug in place
Old Nov 25, 2006 | 07:21 PM
pittguy's Avatar
pittguy
Some owners have stated that the wiring harness and box will hold water.Sealing these areas along w/dielectric grease at connection may be advised.
thomasf59
Oct 26, 2014 09:58 AM
gnewman
Dec 30, 2012 06:46 AM
bimmersixx
Jul 8, 2009 07:01 AM
fatboyartie
Apr 30, 2008 10:15 PM
waynehues
Exhaust System Topics
Apr 3, 2008 12:28 PM
