***Longer Kick Stand for Street Glide***
I would like to know if anyone out there carries a longer, stronger, and stable kick stand for the street glide. I put a 23 inch wheel and 18 inch on the back and it leans alot. I would like a longer kick stand to make the bike stand straighter. I have been told that the stock kick stand are one of the strongest and best kick stands you can get, but it there anyone out there that has changed their kickstand? Please post your pics.
Thank you.
Thank you.
Or maybe had added a bracket or piece of metal to the stock kick stand to make the bike straighter. I mean I know you need the lean so your bike wont fall over, but mine leans so much it takes more room in my garage. Especially when I park by other bikes, when there is virtually no more bike parking...
HOw about spacers?
I have had issues w/ lean angle w/ the stock kickstand when I lowered my bike. I understand your issue is opposite of what I had, mine: not enough lean, yours: too much lean.
After trying to grind the bracket and all, it still didn't give me enough lean (especially after lowering the front.) So I just got some washers (one thick, the other 1/2 as thick) and placed them between the bracket and frame.
It took care of my problem. Only cost me like less than a $1.00!! I should've tried the "WASHER FIX" first.....
Anyway, I suppose you can just put the washers in opposite of how I put it to have less lean. The thick one on the top mounting, the less thick one in the middle/ rear.
Hope this helps!
Hope this helps!
Hope this helps!
Hope this helps!
Hope this helps!
Hope this helps!
Don't mean to hijack this thread. But I'm in the same situation as you, lowered front and rear, plus bolted in a pad onto the kickstand. Now I have to be careful even parking next to a curb. Can you tell me what size washers you use and where do you place them at? I appreciate it.
Ride safe
Mozvader
2014-2023 Touring Models
32
08-31-2014 11:07 AM
