Bagger Kickstand...
Old Apr 23, 2007 | 07:40 PM
tireater's Avatar
tireater
Default Bagger Kickstand...
Hearing about a guy dropping his bike made me remember the kick stand on my 05 Elec. glide stuck straight out...
EverytimeI parked the bike I had a bad feeling as the kickstand didn't seem to figure out what it wanted to do...
I finally removed it and put a torch too it and bent it forward about 20 deg...Now when I park the bike settels back on the kick stand real nice...anyone else modify the stock kick stand...?
Old Apr 23, 2007 | 07:42 PM
JEFE's Avatar
JEFE
Default RE: Bagger Kickstand...
[sm=ttiwwp.gif]
Old Apr 23, 2007 | 07:47 PM
tireater's Avatar
tireater
Just picture yourbagger with the tip of the kick stand approx. 3" forward...not really worth a pic...
My Bob kickstand is different and works OK...
Old Apr 23, 2007 | 07:48 PM
69z28's Avatar
69z28
No,never had a problem with the stand.
Old Apr 23, 2007 | 07:53 PM
tireater's Avatar
tireater
Saw a good one...guy parked his bagger on a slight hill and left it in neutral with the bars turned. No one is close to it and we hear a noise and it takes off backwards - does a 180 and reparked BEFORE anyone could get to it...GOOD TO BE LUCKY...!
Old Apr 23, 2007 | 08:27 PM
alexcue's Avatar
alexcue
talk about good karma, of all the bad things that could happen that wasn't even close...
Old Apr 23, 2007 | 08:43 PM
Smitty0128's Avatar
Smitty0128
i put mine down and lean the bike and always wonder if its stable, I am not that convinence its ever stable -honestly. it has about 2-3 inch flex either way when leaning it down.
i am waiting for me to drop mine.
Old Apr 23, 2007 | 09:15 PM
quad50's Avatar
quad50
Does anyone know what material a kickstand is made of? I've worked with spring material for 35 yrs and I'll tell you that the worse thing you can do is to use a torch on it and let it air dry. Not everytime, but alot with silicon material it will snap when you try and bend it. My $.01
Old Apr 23, 2007 | 09:20 PM
tireater's Avatar
tireater
Not sure but I bent it over a year ago - and it works great...The thing used to give me that sick feeling in my stomach - no more..!
Old Apr 23, 2007 | 09:25 PM
Biggzed's Avatar
Biggzed
My experience has been that harley juffy stands are about the most stable on the market. If you look underneath your bike when the stand is down, the stand is actually locked into a slot. You can rock it back and forth a couple of inches, but there is little chance the stand is going to collapse and let the bike fall over.
Tireater - When you bent your stand, did you actually loose some ground clearance?
