10 limited
Old Oct 8, 2011 | 07:46 AM
hoggy05's Avatar
hoggy05
Default 10 limited
what's the redline on the 10 limited.
Old Oct 8, 2011 | 07:59 AM
traveler's Avatar
traveler
5500 rpm
Old Oct 8, 2011 | 03:45 PM
kdfcogwheel's Avatar
kdfcogwheel
That depends. 5500 rpm for a stock 103. 6250 rpm for one that has a stage 1 with a tuner. Mine has the SE Pro Tuner and was dyno'ed to 6250.
Old Oct 8, 2011 | 04:13 PM
mkich66225's Avatar
mkich66225
4th Gear
doesnt the tuner adjust the limiter?
Old Oct 8, 2011 | 04:37 PM
kdfcogwheel
Apparently it does. The dyno sheet from the dealer at the time of the upgrade showed 5500 rpm before and 6250 rpm after the tuner was installed. In the case of the SE Pro Tuner it is nothing more than a go-between box. It is plugged in-line during the dyno runs. The computer the shop uses talks through the SEPT box to the ECM. All adjustments are stored in the ECM and the SEPT. The serial number is registered to my particular bike/ECM. So, I guess the limiter is reset to 6250 over the stock 5500.
SWThomas
Milwaukee Eight (M8)
36
Aug 7, 2017 12:24 PM
cfave
Jan 25, 2013 06:15 PM
sharkey
Jul 30, 2012 06:22 PM
jchart11
Dec 13, 2010 09:03 AM
Softy 103
Jun 8, 2010 05:26 PM
