throttle cable help
Old Oct 17, 2011 | 11:57 AM
MILLER41143's Avatar
MILLER41143
Default throttle cable help
i sold my 2010 sg and bought a 2005 electraglide se
i am currently changing out to 16 inch monkey bars this bike has the throttle cables.
i cannot get the throttle cables out of the housing, i looked at my new cables and it looks like it has some kinda clip holding it into the housing
what am i missing how do i get this cable to come out of the housing
i have ordered new manual for this bike and jus havent got it yet
thanks
Old Oct 17, 2011 | 12:45 PM
z71_fourwheelin's Avatar
z71_fourwheelin
Its just a retention clip you just have to muscle it out bend to one side and twist as our pulling it. It is aggrivating
Old Oct 17, 2011 | 12:57 PM
MILLER41143
thanks is the clip on the inside of the housing or is it on the out side?
Old Oct 17, 2011 | 01:03 PM
z71_fourwheelin
inside. Ive used a awl before and just pryed it out. especially if your replacing the cables
Old Oct 17, 2011 | 01:12 PM
MILLER41143
ok thanks i called a hd dealer earlier and they said to just pull and it would come out. so do i need to pry this clip out or just pull?
Old Oct 17, 2011 | 01:27 PM
golfblues's Avatar
golfblues
Just pull the MF & it will pop out!
Old Oct 17, 2011 | 02:21 PM
z71_fourwheelin
Just pull but if you cant get it to pull out then youll have to get the retaining clip off. Just dont break your housing.
Old Oct 17, 2011 | 02:37 PM
skully1200's Avatar
skully1200
If you pull straight down, it should pop right out. You do have to pull fairly hard.
Old Oct 17, 2011 | 02:42 PM
MILLER41143
good deal ill pull on it when i get off work
thanks for all the help
Old Oct 18, 2011 | 09:31 AM
MILLER41143
tried pulling last night and they were woo tight i took a flathead screwdriver and a hammer and hit them and they popped right out
thanks to all for the help
got all wiring soldered together last night and will try to pull the wires thru tonight
