Kickstand Replacement
Old Nov 7, 2011 | 09:23 AM
ramnj's Avatar
ramnj
Default Kickstand Replacement
Anybody change their kickstand? PM came out with a kickstand that is 1 inch longer and was wondering how difficult it is to change out.
Seems simple but you never know until you get started.
TIA.
Old Nov 7, 2011 | 09:48 AM
stupid_rope's Avatar
stupid_rope
why do you want a longer stand?
Old Nov 7, 2011 | 10:01 AM
slothy's Avatar
slothy
its simple, secure the bike, remove bolt and kickstand lock plate under bolt - pivot kickstand forward remove spring and install install in reverse.
Old Nov 7, 2011 | 10:26 AM
2black1s's Avatar
2black1s
I agree.
I've had to park my bike on slight side slopes where a longer stand would have been beneficial, but also on opposite slopes where if the stand was any longer than stock the bike could easily tip over to the right.
I think the stock lenth is a perfect compromise for a stock height bike. But that's only my opinion... Others may have differing opinions.
Old Nov 7, 2011 | 10:30 AM
ramnj's Avatar
ramnj
I have a 21 inch front tire.
Old Nov 7, 2011 | 11:49 AM
stupid_rope
So do i...a longer jiffy stand will make it more upright.
you want a shorter one.
Old Nov 7, 2011 | 12:30 PM
ramnj's Avatar
ramnj
Maybe I didn't explain correctly. I have a 2010 Street Glide that comes with an 18" tire from the factory. When I changed it to the 21" rim/tire, it raised the front approximately 1". To address the difference you can either put a longer kickstand or lower the front end with shorter springs. Since I'm 6 feet tall I decided to go with a longer kickstand to address the above. Putting a shorter kickstand would make the bike lean more.
PM designed and manufactured the kickstand specifically for those that did the 21" front tire mod.
Old Nov 7, 2011 | 12:32 PM
ramnj's Avatar
ramnj
Thanks!
Old Nov 7, 2011 | 05:49 PM
stupid_rope
Gotcha...
lower the front to keep the proper geometry when you can afford it.
Old Nov 7, 2011 | 06:27 PM
ramnj's Avatar
ramnj
BTW, slothy, nice bike!
