Exhaust clamps reuseable?
I have wonder why you would ask about re-using the clamps after reading that the manual specifically tells you not to .... do you really place more faith in the opinions of the "experts" on our site as opposed to those who have written the service manual? Don't get me wrong, there are some great techs on the Forum that can offer excellent recommendations, but I can tell you from years of making my living working on autos and scooters that re-using clamps can ( and usually does ) lead to problems in the long run. At $7.95 a piece why would you want to jeopardize your $400.00 mufflers for such a minimal savings. Does the phrase "Penny wise ... dollar foolish" ring a bell. Just my .02 cents worth Brother!
Cheers
txhawg (10-25-2018)
I do appreciate your 2 cents. Now to answer your question. I'm of the opinion and apparently so are many others here that the manual although generally considered the bible can be used as a tool and not as the last word according to the gospel. Would it be a good idea to follow it's every sentence, most likely yes. Is there room for common sense to maybe go against the manual, most likely yes. It's not about saving that 8 bucks per clamp x 4 it's about the thousands of other total dollars that Harley would have you spend that may not be entirely neccessary. Have you ever heard of the millionaire next door? If not it's a great read. Highly recommend. It teaches you to not spend money frivolously. You ask if I trust the folks on this site before the service manual. Well in this case I solicited opinions from forum members on the advise of reusing a muffler clamp in hopes of hearing from members who have 20 plus years dealing with this issue. I am now satisfied that enough competent members have done so with excellent results. The responses have been from those who have done it with success and those who say why be a cheap bastard just replace the clamp. I have not heard from those who tried to reuse and had failures. I call that using common sense. You call it foolish and your entitled to your opinion.
Cheers
Cheers
Cheers
Cheers
Received 48,509 Likes
Cheers
Cheers
I also had the clamp fail. It was an 01 ultra. Seems there was a bad batch of clamps at that time (01,02). So bad a problem that it was difficult to find new clamps. That problem must have been solved because I have since reused clamps with no issues. If your muffler falls off you will know you have a bad clamp.
Actually I have read Mr. Stanley and Mr Danko's publication and I do appreciate their views .... as far as the re-use of the clamps are concerned, my statement was based on an experience that I had regarding service on my scooter. It was in for warranty work ( I generally do all the service myself .. I am a retired ASE certified tech and owned my own shop for over 25 years ) and they had to deal with the rear tire. After I picked the bike up, on my way home I noticed that something was wrong, pulled over and ... bingo ... the right side muffler was completely seperated from the header pipe. They came out picked up the bike and took care of the problem ... the clamp had failed ... the re-used clamp. I failed to include this in the original post and in hindsight this was and error. As far as the "penny wise dollar foolish" is concerned I may have chosen a better phrase to convey my point and if you took it the wrong way my apologies are in order. 'Nuff said.
saltlick
05-24-2014 12:23 PM
